Worn Cam Lobes Pics Needed
Does anyone have any photos of worn cam lobes for a Porsche 944..I would prefer to see a high mileage worn out head with the cams, etc. This will give me a good idea of the condition of the top end of my motor.
Also what is the basic rebuild recommended for the 3.0L motor...?
![]() 1990-Porsche 944 S2 Project Hair Loss 2001-Saab 9-5 BSR Best car I have owned 2008-BMW 328i (Just another beamer) |
Greasy Member
Well, I don't have any pics for you at this time, but a worn down cam is unmistakable! There is a hardened surface on the lobes of the cam, once this hardened surface is worn through the lifter rides on the non-hardened metal and wears down very quickly. A cam that is getting ready to go will have pits or cracked off edges of the surface near the peak of the lobes. A cam that is completely worn will show a darker ground down metal surface at the peak of the lobe instead of the nice chrome looking hardened surface visible on the rest of the lobe.
I may have a couple of worn cams at the shop, if I can find one I will try to take some pics for you later today. Hope it helps, -Nick
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
I think Nick pretty well covered it. I pitched my old ground up cam or i'd get you a pic. It was a low-mileage racing cam I had in my truck....I chewed it up in nothing flat and never bought another crane cam.
Brian '86 944 NA '94 Jeep Cherokee 3" and 31's '86 Chevy C10 425hp '98 Dodge Neon (the wife) |
Crane Cams are terrible
![]() The only thing I notice is a little bit of darker colored metal on a few of the lobes...best decribed as little triangle shaped dark spots on the lobe edges.
