Porsche Crest Problem with Zims Pads on Cams
Hello all,
I just put Zims pads on my cam tensioner and when I started the car the chain was making noise on the pads. I then took the valve cover off and inspected the tensioner, I have good oil, the tensioner seems fine, I pushed it down a couple of times. Put the valve cover back on and the noise stopped. The I started the car up the next day and started to pull out of the garage. The noise is back . I called Zims and they said perhaps the pads need to wear into the chain...hmmmm. Or break apart and kill my motor.
I need help !
1990-Porsche 944 S2 Project Hair Loss
2001-Saab 9-5 BSR Best car I have owned
2008-BMW 328i (Just another beamer)
Old 05-10-2008, 12:13 PM
Replace the tensioner! Not just the pads...
Good luck, George Beuselinck
Old 05-10-2008, 02:04 PM
Custom User Title
Dave L's Avatar
I had the top pad on my S replaced. There was no noise before or after and the old pad actually still looked half decent. I suspect you may have other problems than just a worn pad. How many miles on the car?
Old 05-10-2008, 02:09 PM
After closer inspection, it looks like the new upper pad does not fit correctly, the edge of the chain hangs over just my (mm's) and is causing the chain to make noise on the pad. I am very disappointed in this product. Since it was my lower pad was the bad one, I will put the old one back in for now and order an entirely new tensioner.
Old 05-11-2008, 05:41 AM
Just thinking out loud
mattdavis11's Avatar
I'm starting to second guess the parts those guys sell. A new ignition switch lasted 3 months! I digress, being 10 minutes from my home makes them pretty attractive.
91 FJ80
84 Ram Charger (now gone)
Old 05-11-2008, 06:23 AM
rickharrison's Avatar
Was the pad put on backwards? Mine fit and work perfectly. I got them from Zims too.
Rick Harrison
1988 944S
17 inch Cup 2's, euro bumper conversion
Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake
MaxHP chipped
Old 05-12-2008, 10:35 AM
This is a really confusing problem. When I put the old upper pad back on it no longer fits correctly either. For some reason the chain is no longer centered on the pad ??? There is no way to put the pad on backwords and there is no way to adjust the tensioner from left to right...CRAZY STUFF ! All I can do at this point is hope the chain wears the pad down and the noise stops. I need to get a new tensioner very soon...almost like somehow the tensioner was bent...how I have no idea...I will take pictures tomorrow, and will attempt to figure out the problem once more.
Old 05-12-2008, 10:48 AM
? hmm...the tensioner isn't installed correctly? weird, wild stuff.
Rick Harrison
1988 944S
MaxHP chipped
Old 05-12-2008, 12:18 PM
yes I installed the pad backwards...I feel like the biggest numb
Old 05-12-2008, 12:22 PM
Quality
phoenix_iii's Avatar
Edit original post to reflect found results.
[glad you found it]
85.5 944 NA 5spd - Sold but not forgotten
89 951 Turbo S - Revival in progress...
Old 05-12-2008, 01:33 PM
