-   -   Rear hatch issues (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/410450-rear-hatch-issues.html)
JamesO 05-21-2008 01:28 AM
Rear hatch issues
My 89 944 hatch has never opened with the key since I bought it a year ago,
This wasn't a problem since the remote worked just fine.
I did test the microswitch with a multimeter and its fine, so put up with it.
Now though if I hit the release button the hatch unlocks but doesn't re lock, you have to hold the button until the motor cycles and locks again.
The motor unit faulty?
Any clues?
bud9344 05-21-2008 05:04 AM
Check the lock with out the hatch being there, lift the hatch and hold it up. And see where the hole is, there is blade work like a scissors open and close? If it does spray some lubrication like WD40 to clean it and use White Litium grease or spray. Make sure that the drain pipe is connected.
Good luck and Have a nice day
Bud
87 930 Black 56000 mile
86 951 Black daily driver
87 944S White Son daily driver
83 944 N/A Auto wifes
83 944 N/A money pit
JamesO 05-21-2008 06:07 AM
Exactly what you said thanks very much!
