Rear end noise
I've got an 84 944. The problem is roaring in the rear. I took it by the tire shop and the tires were wearing bad on the inside. Replaced the 2 rear and still the roar which of course is worse the faster you go. There is also an occasional click or clunk at steady highway speed from the rear.
I'm planning on replacing the rear drivers side half shaft(rebuilt). Could there be some other issue to consider? Wheel bearings? Thanks for the help
Old 05-28-2008, 02:24 PM
Send a message via AIM to bholmes
Sounds kinda like CV's to me. The transaxles on these things are a little noisy too though...but it's a whine, higher pitched like. Also the wheel bearing is quite possible, but the clunk sounds like CV. Change the CV's and if it still does it, try the wheel bearings.
Brian
'86 944 NA
'94 Jeep Cherokee 3" and 31's
'86 Chevy C10 425hp
'98 Dodge Neon (the wife)
Old 05-28-2008, 02:36 PM
Check:
Rear wheel bearings
Rear CV joints
1990-Porsche 944 S2 Project Hair Loss
2001-Saab 9-5 BSR Best car I have owned
2008-BMW 328i (Just another beamer)
Old 05-28-2008, 02:44 PM
