simple brake bleed question
If I power-bled my brake fluid this weekend, did the fluid in the clutch master cylinder get changed too? I tried a search but maybe didn't go deep enough.
Thanks Bill K (87 944 S) |
only if you opened the bleeder at the slave cylinder.
nate |
thanks nate.
....and this bleeder is opened best by removing the starter? Bill K |
I've managed to do it without doing so, but I did use a length of windshield washer tubing to keep the fluid from running all over the place. i also had my car on my friend's lift :(
nate |
| All times are GMT -8. The time now is 06:16 AM. |
