-   -   Another quick spring rate question. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/412667-another-quick-spring-rate-question.html)
UomoBello 06-02-2008 06:55 PM
Does anyone know the spring rate of the M030 springs?
Thanks,
Tony
flash968 06-02-2008 07:34 PM
for what model and year? there are different ones - as an example:
924S and 944 up to MY 86 were 140#
944S2 and Turbo were 160#
these were also different lengths
UomoBello 06-02-2008 10:09 PM
944 S2's. I am upgrading the suspension on my '83NA and I already have the 25.5mm torsion bars. Now I am trying to find out if the 200# springs from Weltmeister would be a good bet with those torsion bars in order to keep the suspension balanced.
flash968 06-03-2008 05:25 AM
25.5 torsions are 175lb wheel rate
depending on the weight distribution, the 200lb springs may be a touch too stiff for the ultimate balance - if the rear is light though, they would work well
