Exclamation Hot start question
My 84 starts great cold but once hot, it won't restart till it cools. The tach does not
jump while cranking. Once it cools off I can see the tach jumping and I know it will fire up. I replaced the fuel dme relay and checked everything else as the manuals recommend. Is it a fair bet it's the reference sensor(s). Are the reference sensors independent of any other system if the car cranks over well.
Old 06-03-2008, 01:47 PM
Learned by do'n twice
The reference sensors feed the DME. There's a power transistor (mounted on a heat sink) in the DME subject to solder joint failure. Since you already replaced the DME relay you might want to pull the DME and inspect the power transistor for cracked solder joints. There's a good writeup on the rennlist forum. You could also check the connection of the reference sensors to the main wiring harness
jmd_forest
86 944 NA - Brought back from the dead
Old 06-03-2008, 04:34 PM
Dme
Actually I swapped the DME with a known good one and the car started right up.
It's just the hot starts now and no Tach movement that are the issue.
Old 06-03-2008, 04:47 PM
Professional Bull5hiter
Outback Porsche's Avatar
This sound very familiar to me. Have you read my post;
Another 'Intermittent Start' Problem
Jeff
Jeff
83 944 Guards Red
23 718 GT Silver
Old 06-03-2008, 05:04 PM
Start problem
Keep me posted how you come along , I'll do the same.
Old 06-03-2008, 05:42 PM
Sure.
The last thing I did was clean up all the ground points in the engine bay (incl engine, and terminals on alternator, battery, etc). Now going to drop the relay/fuse panel under the dash and clean, along with the ground point behind it.
Jeff.
Jeff
83 944 Guards Red
23 718 GT Silver
Old 06-03-2008, 06:20 PM
