Strange noise after starting.
Hi folks,
I have a 1989 2.7 944, that make a strange new noise after starting, and moving off. I have never had it do it in reverse, which is how I get out of my drive. Within a couple of seconds of moving off forwards, a strange, guite loud brrrrrrrrzzzzzzzzzzzzzztt noise taking two seconds occurs, but does not repeat. Sounds like it's coming from the drivers side wheel arch (I'm European and so is the car, so this is the right side..!) ABS? Steering Pump? any other thoughts? It didn't happen, and now it does. Weird. Cheers Russell
944 Alpine White '89 2.7L |
Quality
More info for those who can help.
Is it only cold starts? Is it once a day? Is it every start (from a stop)? Is it easy to reproduce if you stop, turn car off, then back on, and take off? What if you leave it in neutral and just push it forward? Details!
85.5 944 NA 5spd - Sold but not forgotten 89 951 Turbo S - Revival in progress...
Cold starts, or warm starts, in fact every start, but only after I move off.
Don't know if it will happen after an immediate restart, (I'll have to test) but I think it does. Leave on in neutral and push: I will try this, next chance I get. The noise is electrically started, I'm fairly sure, as if a switch is operated for a few seconds then stopped. Thanks for the ideas. cheers Russell
Most likely the ABS pump. It does the same thing on my previous S2 after start up and moving off.
The ABS pump finally went out after one year and had to disable the ABS system to turn OFF the "!" and ABS light.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
Feelin' Solexy
Bazar01: what "went" on your ABS and how did you disable the system?
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
Back from Beyond
Fuel pump? Although it may whine more than the sound you describe.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
Hi,
Tried a further test: on a straight bit of road, doing 40 mph, turned of the ignition. (Clutch down, obviously). Turned on the ignition, and this noise occured before I had re-started the engine. I had the window open, and I reckon the noise was from the wheelarch, so may well be the ABS pump. It's definitely not fuel pump. Does the abs pump have an electrical interface? Does it pump up after engine start? It must sense wheel rotation. Any info on how this stuff works and what I can check out would be most welcome. Cheers Russell
OK, it is the ABS pump making a noise.
Test Cycle acording to Mitchell: A test cycle runs in the ABS control unit when ignition is on, and another runs at a road speed of 3mph. ABS test at 3mph can be felt, since the pump in hydralic unit will run briefly. Test cycle repeats each time vehicle accelerates. I wonder if I have a brake fluid leak, or if the pump is shot. Maybe, it has had a knock and is resonating against the wheel arch. I shall investigate more at the WE. Anyone else had ABS pump noise and cured it without replacement..? cheers Russell
There is a T40 connector in the electrical schematics under the dash in the passenger footwell. I think it has about 4 wires and it's a black connector just above the DME.
Feelin' Solexy
Good to know, thanks!
