Help- Burning oil under load, oil in AFM
The other day I noticed that my AFM had oil laying in it, not my TB though. Today I noticed when i was around 5k under load the car started smoking when i was on a hard pull say to 100 (on my closed coarse test track). It didn't to it noticeably on short pulls on the back roads. I ran a compression check just in case and it was OK. I put my thumb over the spark plug holes and it blew my thumb right off....no really, my numbers were: cyl.1:169 psi cyl.2:171 psi cyl.3:172 psi cyl.4:165 psi goin from front to rear. So what's you guys best guess/diagnosis? I'm thinking oilseperator maybe. Does that make any sense? TIA
Brian '86 944 NA '94 Jeep Cherokee 3" and 31's '86 Chevy C10 425hp '98 Dodge Neon (the wife) |
When did you install the K&N filter?
Good luck, George Beuselinck |
K&N? I used to have a cone filter, but I haven't had that for several months. I just have a plain puralator paper filter and stock air box. Is that a problem with high flow filters?
I think he was just joking, K7N filters use oil to filter stuff out. ANyway I think its your air oil sep. Check the seals.
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
I'll put that on my to-do (soon) list. Wonder if this could also be related to my [decel-backfire, smoke on decel, not pulling to rev limmit properly] problem....hmmm
I'm lookin for them here on pelican, but can't seem to find them. any other names to look under. What exactly am i looking for...what part do I need?
999-701-613-40-M104 and 999-701-661-40-M100 is that all I need?
anyone know if those were the right part numbers to fix my alleged problem?
