Lower Fender (wing) repair panel
I need to repair some rust at the lower part of the front fender - rear of the front wheel across to the rocker panel. Does anyone know where I can buy repair panels for this section - US source is fine as is UK ...anywhere for that matter? Steve
Old 06-14-2008, 04:03 PM
Learned by do'n twice
Steve,
Not exactly sure the area you're speaking of, but regardless, you'll probably find it cheaper and easier to simply replace the entire fender with a good used one. Rust is difficult to repair correctly. If you shop hard enough and are a little lucky, you might even find one the right color.
jmd_forest
86 944 NA - Brought back from the dead
Old 06-14-2008, 04:35 PM
