Quality
phoenix_iii's Avatar
Question What is this capped off guy and his chewed up friend?
Goes to exhaust and is getting dripped on apparently...
and his chewed up friend? =(
Thanks!
85.5 944 NA 5spd - Sold but not forgotten
89 951 Turbo S - Revival in progress...
Old 06-13-2008, 11:02 AM
75ohm's Avatar
Exhaust test point...
www.rennwish.org
'88 944 NA - Red/Black with more tinkering done than probably needed.
Old 06-13-2008, 11:09 AM
Quality
l0l. One down. If you're being serious that makes perfect sense. #2?
Old 06-13-2008, 11:14 AM
75ohm's Avatar
Yes!
Timing mark sender... *I think*
www.rennwish.org
Old 06-13-2008, 11:29 AM
75ohm's Avatar
Other two that it is attached to are the speed and ref sensors...
www.rennwish.org
aj951's Avatar
The "drippings" on the exhaust test port bracket is most likely oil leaking from the rear cam tower gasket. My test port bracket looked exactly like that and a $1.00 cork gasket fixed the problem. I am not positive but I thought #2 (chewed up friend) was the interconnect between the O2 sensor and the main wiring harness.
A.J.
89 944 Turbo
Guru Chip
Lindsey Boost Enhancer
3bar Reg.
Old 06-13-2008, 11:38 AM
Yes, 'chewed up friend' is wiring for O2 sensor.
'84 944 - new-to-me DD!
'83 944 - looks like ass, runs like horse - in primer.
'82 931 - roadster project - forever incomplete.
'80 924 - spouse's yellowjacket.
Some wrecks and a 924 racer.
Old 06-13-2008, 12:05 PM
Quality
Thank you guys.
Fortunately (can't tell in pic), it's JUST the insulation. I'll put some heatshrink on it and make it look better. =)
Old 06-13-2008, 12:25 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
1st one is the exhaust test pipe. Not used for anything but the factory.
2nd is the O2 sensor
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 06-13-2008, 04:32 PM
