Send a message via AIM to bholmes
anyone rebuild air-oil-sepparator?
Has anyone rebuilt an air-oil sepperator? How do they work? What parts do I need? Or do i just need to get a new one?
Brian
'86 944 NA
'94 Jeep Cherokee 3" and 31's
'86 Chevy C10 425hp
'98 Dodge Neon (the wife)
Old 06-16-2008, 03:55 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
What's to rebuild them? They are made of plastic.
If you need one I have one for sale. Needs the orings replaced. Send me a pm if you want it.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 06-16-2008, 04:29 PM
Funniest thing. I was showing my friend how it worked, where it got vaccuum etc and noticed a crappy kinked rubber line. The vacuum hose to the j-boot was totally kinked and this caused there to be WAY to much crank case pressure. So I think I got this problem nailed. We'll see....now for that stupid backfire problem...though this would have fixed that.
Brian
'86 944 NA
'86 Chevy C10 425hp
Old 06-16-2008, 06:38 PM
What Are The Part Number For The O-rings ?
Old 06-17-2008, 02:38 PM
999-701-613-40-M104 and 999-701-661-40-M100 is that is? I just figured there was more to them than that....but then again unkinking that hose fixed a few of my problems. But now I'm begining to think my AFM is out of calibration.
Brian
'86 944 NA
'86 Chevy C10 425hp
Old 06-17-2008, 02:40 PM
Nope, it's just an empty container..... And an expensive one at that.
Jack
86 Porsche 951 - LR 3" Exhaust, MaxHP chips and ProfecB @ 15psi
83 Porsche 944 - Still under re-construction.
08 Suzuki Boulevard M109R LE
02 Nissan Altima SE3.5
Old 06-17-2008, 03:58 PM
Good deal! lol
Brian
'86 944 NA
'86 Chevy C10 425hp
Old 06-17-2008, 05:51 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
How it works......Takes the mist created by the engine crank spinning and removes the air in the separator and back to the crankcase. Simply put oil turns to mist and then returns to liquid and back to the engine. The oil you see leaking is the oil/mist passing the 3 seals. Not a tough repair but labor intensive as the intake comes off so new gaskets are a possibilty there. Drain the case to help spillage out the lower port to the separator/block.
A/O..... Same thing as a PCV unit on a Domestic
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 06-18-2008, 06:53 AM
cycling has-been
bkreigsr's Avatar
not as simple a design as it appears.
there are a two fixed baffles inside, one to help direct poured oil to the proper locations and one to direct the fumes to the hoses. The top must pry off somehow as it has a ring of snap dimples.
Bill K
Old 06-18-2008, 07:40 AM
I think i've got it figured out now. It's alot simpler than i thought. Thanks for the explainations! I'm gonna see if it continues to leak since I fixed the rediculous crank case pressure that was causing oil leaks. I know my car isn't doing the smoke-on-decel problem now that I fixed that so I'm quite pumped about that.
Brian
'86 944 NA
'86 Chevy C10 425hp
Old 06-18-2008, 08:43 AM
kwikt 911's Avatar
I found one on e-bay for $10 and replaced it myself on the 968. Actually it's a pretty simple job but the intake must be removed(no big deal). I didn't have to drain the oil to change the separator, but then again this is on a 968. The total job took less than 3 hours and that was taking my time.
Kevin
Old 06-18-2008, 08:47 AM
Redline Racer
HondaDustR's Avatar
I did mine when I did my intake gaskets/fuel injectors, and I didn't need to drain any oil.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 06-18-2008, 01:02 PM
Bill K
The 951 is that simple, maybe the N/A versions are different. I've had the top off of mine, pretty much it's just a plastic cup with 4 ports on it. There's a little bit of a design to the top vacuum port, but I wouldn't even really call it a baffle.
Jack
Old 06-18-2008, 03:42 PM
What bkreigsr is refering to is the baffle in the oil pan, not the air/oil seperator.
The NA is no different then the turbo. 3 bolts and it's out. Much easier if the intake manifold is off though.
86 Metallic Grey
Old 06-18-2008, 04:13 PM
