Z06C5R's Avatar
WHY can't I bleed these brakes?
This car never ceases to amaze me... I completely flushed the brake system on all 4 corners, in the right order, using the right procedure, etc, etc. After running at least 2/3 of a 1L brake fluid bottle through the system, I STILL have a ridiculously long pedal and pathetically little braking power.
I started at the right rear, then LR, RF, LF. I pumped them until clean fluid came out using the standard buddy-system procedure and always keeping the reservoir above 1/2 full, and yet they're no better than when I started. WHAT is going on here?!?
1985 Porsche 944 - '85/1 N/A, currently for sale.
1971 Datsun 240Z - Street / AutoX car.
2005 MINI Cooper S - Insane daily driver
Old 06-18-2008, 02:52 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Bleeding brakes is such a pain to do, even with the buddy system. What I used to do before I got a Motive bleeder was to get them as best I could, then at night when there was little to no traffic, drive it to the shop....taking my time....and let them get it all the way done. Never more then an hour of labor charge and much easier.
And that's after replacing at least a dozen master cylinders on various cars over the past 20 years.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 06-18-2008, 03:15 PM
Z06C5R's Avatar
I don't see why it doesn't work... I've bled brakes tons of times before, and it's ALWAYS worked fine. Hell, even the clutch on this car worked, it's just the stupid brakes.
Old 06-18-2008, 04:29 PM
DSPTurtle's Avatar
There is the old trick of get 'em hot and bleed 'em again. Sometimes they just need to be warmed up a little. At least that is what worked on my old 914.
Then again, you never did tell us why you started messing with the brake system in the first place... was there another issue that now the new pads are no longer hiding?
At the end of the day, when I am totally frustrated, I just open all four bleeders without touching the pedal and allow them to drain through. I keep adding fluid to the resevoir while they just keep dripping for awhile. Your mileage may vary.
Is it possible that your "buddy" does not understand the finer point of hold it to the g damn floor until I tell you that the f'ing bleeder screw is tight??? I have had a few of those in the past too
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 06-18-2008, 04:38 PM
Z06C5R's Avatar
Trust me, I lecture them extensively on why NOT to move their foot even a fraction of a mm until I tell them to, LoL.
I decided to replace the pads because the stopping power and feel they were providing was sub-standard in my book, and they were only a few mils from the wear sensors anyhow.
EDIT: Tried the hot-bleed, no result. Going to see if I can obtain a vac-pump tomorrow and try that.
Old 06-18-2008, 04:43 PM
earlr85944's Avatar
were the brakes spongey before bleeding? could be a bad master cyl, leak in system or worn brake hoses (sometimes they expand when worn)
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 06-18-2008, 05:58 PM
brake master prolly.
hope to god it isnt the brake booster.
absolutely the worst job ive ever had to do on the 944.
Old 06-18-2008, 05:59 PM
Z06C5R's Avatar
Yeah, great - Because I'm just psyched to put yet another paycheck into this supposedly "well maintained" pile of dung...
But seriously, they weren't spongy before... Certainly not like now for sure. I can't see how putting new pads in would make it more worse. How would I diagnose a bad master by means other than brake feel... I'm assuming I'd be having inconsistent pedal height / travel, no?
Old 06-18-2008, 06:25 PM
DSPTurtle's Avatar
If you get in the car, you have to pump up the brakes and then press hard on the brake pedal. If it slowly sinks to the floor the master cyl needs to be replaced. I did the SS brake lines on mine a few years back to replace the worn out hoses. Talk about being a ***** to bleed out the air after that!!! Don't waste you money on the vac pump. I had a mitty vac that I got from our host. I smashed it against the wall after the first use... it actually made the brakes worse each time I used it! YMMV
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 06-18-2008, 06:46 PM
Z06C5R's Avatar
Well, the pedal holds damn firm after a few pumps if the engine is off, but I haven't tried it with it on.
If no mityvac, then what? Is it even possible to bleed these crappers fully w/o a pressure bleeder? Damn this car really irks me!
Old 06-18-2008, 07:07 PM
earlr85944's Avatar
yes the old pump crack open method does work
83 944....bye bye
Old 06-19-2008, 02:38 AM
flash968's Avatar
never ever ever pump brakes - if you are going to do it manually, do it one stroke at a time
closed - push moderately to floor - buddy opens on downstroke - you hold at bottom - buddy closes - release
Old 06-19-2008, 07:01 AM
Send a message via AIM to Lapponia
How did your old brake fluid look like before change? Was it ink? I can see many brake fluid container in pictures here at Pelican and that is a sure sign of BAD oil and prob water in it.
This issue has been up here several times an I remember one a year ago or so. Your brake master cylinder seals are prob shot because you bottomed the piston in its cylinder when passing a little fang of rust deeper in at the cylinder wall. Its rust....belive me, I had it and was prepared when i changed the seals. Had to polish/rub whole inside of cylinder top to bottom with very fine emery cloth, cleaned and lubricated both piston and cylinder. There WAS a blob of water in the cylinder and there was this fang of rust which I could remove. Gave same treatment to clutch master cyl and slave. Bleeding was very straight forward with wife (buddy) at the pedals the old fashioned way. Had no problem what so ever after that. BTW, I changed all bleeding nipples and caps at the same time.
Lapponia 1984/944 na
Old 06-19-2008, 10:29 AM
Z06C5R's Avatar
Well, after attempting my 4th bleed (this time with a newly acquired mityvac) with no result and comparing the brake pedal feel to a few other cars, I've determined it to be a bad master.
Funny how trying to do something simple and easy like replace brake pads results in a broken master cylinder. Am I having fun yet?
Old 06-19-2008, 10:45 AM
Aufenbahn's Avatar
Did you install new rotors also? If the new pads are perfectly flat and the old rotors are not perfectly flat, you won't get a good feeling pedal until the pads wear-in to the shape of the rotors. Just a thought...
Andy D.
Currently driving 2005 Audi A4
Currently driving 1998 Grand Cherokee sometimes
Old 06-19-2008, 05:48 PM
your average wrencher...
never push the brake pedal farther than normal, as if you were braking. master cyls develop dirt and gunk where the brake pedal isn't pushed past. when you push it past these, the rip the seals on the inside and the it needs new seals then. it won't properly work or even bleed your brakes.
1986 951 Garrett turbo, Rogue Tuned.
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
1988 XJ 5in lift,long arms, 4.6 stroker, ax-15 w/ 35s
1995.5 Audi S6 Full RS2 bolt-ons, EFI tuned.
Old 06-19-2008, 05:52 PM
Nobody Special
Guess you haven't done a clutch yet?
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 06-19-2008, 06:13 PM
Why do you think it's the master cylinder? I doubt it that. Still sounds like you have air in the system.
86 Metallic Grey
Old 06-19-2008, 06:37 PM
DSPTurtle's Avatar
I agree... keep bleeding till you can't bleed no more. Did you open all four bleeder and just let them drip yet?
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 06-20-2008, 07:59 AM
Banned
My sugggestion is to spend the money an buy a power bleeder. It's $45 at Pelican and is one of the greatest tools. If you have a power bleeder, your more likely to flush your brakes periodically like you are supposed to because it makes the job so easy.
Besides, getting a power bleeder, get brake fluid that is a different color that what you have now (like super blue). Simply fill the resivoir, attach the pressure bleeder to the master cylinder and pump to 15psi. The start with the passenger side rear and open the brake bleeder (using a tube to catch the fluid). Keep the bleeder valve open unitil the fluid changes color.
Now check the resevoir and top off (no need to put any fluid in the pressure bleeder). Attach the power bleeder and pump to 15psi. do the next wheel (driver side rear).
Follow the above steps for the passenger front and driver side front last.
If you really want to be thourough, do the whole process again. Nothing beats a power bleeder - you will get all the air out. and if you still have a soft pedal, it's probably your master cylinder.
Vern
Old 06-20-2008, 09:59 AM
