-   -   84 is eating O2 sensors (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/415951-84-eating-o2-sensors.html)
shikzachaser 06-22-2008 04:54 AM
Anybody had their N/A eat O2 sensors every couple months? I have been having a rich mix for a while and have replaced the O2 sensor 3 times now in 5K miles. It is dead again. I have used a stock one and 2 generics from Auto Zone. I have done a few things to the engine but nothing too crazy. I am running MSDS headers and a mini cat. The O2 sensor is in front of the cat in the threaded hole on the header. Any ideas???
Britwrench 06-22-2008 10:00 AM
It probably isn't the O2 sensor. If it's running rich there is another reason. What diagnosis have you done? The car will run with the sensor disconnected anyway.
shikzachaser 06-22-2008 03:56 PM
I have a quick disconnect and have measured the voltage from the DME @ right @ 4 volts. All of the O2 sensors have been at least outputting voltage in the 4-5 volt range when installed. I have adjusted the A/F to get close then after a couple hundred miles it is rich again and the output voltage from the O2 sensor is essentially 0. If I stick a new one in it again gives me an output. I am at a loss. I also am not the sharpest tool in the shed and am receptive to ideas.
JivenJim 06-23-2008 07:24 AM
FPR or Sticking Fuel injector??
Get Injectors Cleaned could be a start. Vacumm test on FPR to see if it holds perssure.
AFM worn contact?
