924S servicing schedule
Hi folks - my neighbor has a 924S with 79K miles on her that has been parked for nearly 15 years. What should I expect by way of reconditioning / servicing schedule to get her back in the road properly?
Thanks,
Tom
Old 06-23-2008, 08:27 PM
Toofah King Bad
Rasta Monsta's Avatar
It should be towed to the shop for belts (front of engine service) before you attempt to start it. Draining the fuel tank, replacing fuel filter, changing oil, coolant, brake fluid, and gear oil is also prudent.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 06-23-2008, 10:14 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
Also, if the parking brake has been on, it will be seized by now. The disc rotors will probably be rusted out, but may have enough surface left for skimming. Use a wrench on the crank to turn the motor over quite a few times once the belts/oil are changed prior to turning on the starter with ignition disconnected , only then start it up properly..
Old 06-24-2008, 03:06 AM
Proprietoristicly Refined
John_AZ's Avatar
It may look tempting to help your neighbor remove the lawn ornament, but the cost will be more than just buying a running 924S. Here is an example:
http://forums.rennlist.com/rennforums/showthread.php?t=438303.
15 years=$$$$$$ in replacement engine, body and interior items. Hell, the speakers (4) and radio will cost $300 just to hear Amy Winehouse or Steppenwolf.
It is hard to turn away from a project. I saw you also took a look at a 911 and 993 in earlier posts. In any case, good luck.
John_AZ
Old 06-24-2008, 05:17 AM
Thanks guys - good advice.
Out of curiosity, where is the fuel tank drain? I crawled under the car last night and couldn't located it.
Old 06-24-2008, 06:51 AM
Good morning - thanks for the info. The car has been garage stored the whole time in Southern CA, and believe it or not there isn't any rust anywhere. Not on the disks, body, wings. We are kind of spoiled that way I guess (my Triumphs still rust however - lol)
Even the handbrake was free and operating properly.
Good tip on getting some oil flowing before starting her. Thanks.
Old 06-24-2008, 07:45 AM
John_AZ
The rational side of my brain can't help but agree with you, but..... (you know how this goes).
Actually, the body and interior are immaculate. I think I'm dealing with a mechanical reconditioning, which could easily exceed the value of the car of course.
Thanks for keeping me honest.
Old 06-24-2008, 07:49 AM
John_AZ's Avatar
Bottom of tank: Use a locking pliers on the "S" hose, disconnect from fuel pump.
If you start with the tank and empty it, there is a check valve at the other end of the fuel pump that should be cleaned as well. This check valve keeps pressure in the lines to avoid a long starter crank(ing).
If the dash fuel needle does not register, there is a cleaning procedure from our sponsors "Tech Section"
http://www.pelicanparts.com/techarticles/911_fuel_tank_sender_replace/911_fuel_tank_sender_replace.htm
The fuel tanks also have a tendency to crack on top.
John_AZ
1988 924S + 1987 924S
Old 06-24-2008, 07:51 AM
