help identifying euro or reg part numbers
I am stripping an engine that I was told had the possibility of being a euro? I can't seem to track down the part numbers and thought someone might be able to help
head is 944.104.303.7r cam tower 944.105.250.6R pistons/rods say Mahle P0021 DLOR109 10DlT9 What part number would the block have? Whew, thanks |
Are you referring to the engine type such as M44/07 if so post the year/model and I can give you the number. But if you are looking for the block part# I think it is on the block near the reference sensors.
Dal |
The block number is 9441011101R
underneath that is 046-1 Thanks for any help! |
anyone?
I had a euro engine that I just trashed, I think the basic p/n's are the same, major difference is in pistons and are readily seen. The type # should be on the block near the ref sensors. I have been told that cams, etc are all the same. I saved pistons and rods, head, cam tower, if those #'s will help you I can get them.
I have a 83 Euro, pistons are flat on top look at
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/267818-picture-euro-piston.html |
| All times are GMT -8. The time now is 12:34 AM. |
