-   -   before replacing the master (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/417872-before-replacing-master.html)
Arizona_928 07-02-2008 06:10 PM
before i replace it is their anything i should look out for, and how many hours labor should be?
i'm also planning on replacing the slave, and the hose that runs from the slave to master.
thanks Levi
DSPTurtle 07-02-2008 07:05 PM
What were your symptoms? Is it leaking or just mushy? Mushy could be a bad brake line...
hpservertech 07-02-2008 07:57 PM
Which master? Clutch?
Just follow the steps on clarks.
MAKE SURE YOU TAKE THE BATTERY OUT!!!!
It's a pain to do though. Figure 3 hours to do the master. Hour for the slave and an hour to bleed it all if you dont have a pressure bleeder.
Slave is easy though.
