To buy or not to buy???
Hello 924 folks,
I have an opportunity to pick up a 1 owner 22,000 mile 924 with a really solid body and good interior as well. It hasn't run in about 4 years and before doing anything would do timing belt, water pump and roller. It'll need a cut/polish of the paint and maybe a respray on the nose. Otherwise it is excellent. I have no idea what retail price would be, but my intent is to buy, fix, sell. It is an 81. Looking at a $1k buy price.
What say you?
Thanks in advance,
Tony
Tony G
2000 Boxster S
Old 03-04-2020, 09:44 AM
Sounds like a very good price bordering on a steal depending on condition.
Old 03-04-2020, 11:40 AM
Thanks, but I'm trying to figure out what the retail price range should be. Any suggestions would be helpful. Looks like decent runners are in the 3-4k range. It has to be VERY exceptional to get close to 9k. I don't know what would make it that exceptional. Just looking for what those in the know can share.
Thanks again,
Tony
Tony G
2000 Boxster S
Old 03-04-2020, 12:53 PM
In the Fires of Hell.....
kdjones2000's Avatar
It's a 924, not a 924S. Not an interference engine (2.0L from a Volkswagen van). So you don't need to worry about timing belt/rollers like you do on the 944's and 924S.
Clean it up and put it on bring a trailer and you might get a decent price.
Maybe 3-4k, maybe more?. 924Board.org :: Index is a better site for this information.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 03-04-2020, 01:19 PM
Thanks. I’ll check out that site too. Did not know about the non- interference part. Good to know.
Old 03-04-2020, 01:44 PM
9FF 9FF is offline
9FF's Avatar
If the service records confirm the mileage, everything is kept original including the paint, original radio, all factory options intact, and it’s as good as you describe $4-6k.
Take care though, if you find it needs work like suspension, bushes, clutch, torque tube bearings, etc., you can easily spend more than the car is worth and not have an evening or weekend to yourself for the next month. Folk don’t buy 924’s as a value proposition.
Old 03-04-2020, 02:21 PM
Patrick
pfarah's Avatar
Or, if you're like me, the last 8-9 yrs...
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 03-04-2020, 05:33 PM
Although this one sounds like it is better than usual, as a general rule, trying to flip 9424's for a profit is a bad strategy due to their low value. It would be a lot easier to justify if you were going to keep it and drive it for a while and get some pleasure out of it before you sell.
Old 03-04-2020, 10:38 PM
Misunderstood User
Agree with this. 924 board should give you the info you need. $3- $4K sounds about right. Presumably it's not a turbo - which is a more desirable car.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 03-05-2020, 04:17 AM
Thanks everybody. I appreciate the feedback and info.
Tony G
2000 Boxster S
Old 03-05-2020, 10:24 AM
