Army Wrench Turner
Ctan's Avatar
Question 84 944 Power window N/S?
Having a rough issue with my pass side power window. Getting power to and through the switch but she doesn't want to work. Buddy I bought the car from said every year after storage he had to open the switch and clean the contacts before the window would work. Did that and still no dice
Tested it last night, 75ohms resistance through the motor. I'm figuring the motor's shot out. If so is there any special tooling for removing door skins?
Anyone else have this problem before?
- '84 944 (Black)
Old 07-05-2008, 10:26 AM
Send a message via ICQ to bud9344 Send a message via AIM to bud9344
Yes! It,s a Phillips screw driver LOL
The only thing that you have to watch for is the hand rest top part it doesn't separate from the door skin. After all the screws is off(Including the hand rest bottom part) and release the clips on the door skin. Lift the door skin together with the hand rest Up ward and is off the door. And also take the switch off .
Good Luck .
_____________________
Bud
87 930 Black
86 951 Black
86 944 N/A red part car
87 944 S White
83 944 N/A Black
83 944 N/A White Auto
Old 07-05-2008, 12:11 PM
Ooops I didn't notice you have an 84 model.
I remember having that kind off problem with my 83 and every time the window doesn't work I had to take apart the switch to make it work up to the point it still not working after cleaning the switch. I end up replacing the switch with new one.
Bud
Old 07-05-2008, 12:19 PM
Bud
Army Wrench Turner
Ctan's Avatar
thnx bud, I'll take er apart and see what's tickin back there and what isn't
- '84 944 (Black)
Old 07-05-2008, 01:36 PM
Misunderstood User
Get an interior tool from your local auto parts store. I looks like a 2 pronged fork. It is very helpful separating the panel from the door. There are plastic plugs embedded in the panel. You could try a screw driver, but you run the risk of popping the plug away from the panel. Then you need to glue the plug back in because the panel is essentially cardboard.
This tool is very handy and is not very expensive.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 07-07-2008, 06:33 AM
