shivered's Avatar
Exclamation Please Help!
I dont know why, but this week is a ****y one.
First I think a have a fuel problem. When a start the engine the fuel consommation look high (like 14l/100km on the dash gauge) after a couple of minutes its more normal but on the highway at 5000rpm it smell et sometime I have some black smoke. I've but a injection cleaner last week but it only resolve the problem of smoke. It is the DME the problem?
second, yesterday when i drive home from work the dash voltmeter was showing 11V, at home, it was 10v. I let the engine turn and after 5 minutes every thing shut down it self. I presume its the alternator, but it like weird, an hour later a jump start the battery, and I had a 20minutes ride, the battery was drain down, so if it was the alternator...it sould not run, right?
finally, (I have this problem for a month) alway in the dash unit, beside the voltmeter, there a meter for the oil pressure, when the car running it always show at the top. Maybe its a sensor somewhere, it is the oil presure sender? what you think.
thanks
Old 07-08-2008, 07:09 AM
Toofah King Bad
Rasta Monsta's Avatar
1. O2 sensor?
2. Alternator (take it in for free test)
3. This is normal - check your Owner's Manual
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 07-08-2008, 08:34 AM
Learned by do'n twice
1) Excessive fuel consumption: check the O2 sensor and Fuel Pressure Regulator. Pull the vacuum line off the FPR and look for raw gas in the line. If raw gas is there, replace the FPR. Use a spare vacuum line on the FPR and suck through it to make sure it will hold a vacuum, if not, replace it.
2) As Rasta noted: have alternator tested, or simply replace it.
3) If the problem has only been for the last month, something may be wrong. Once the car is hot, the oil pressure generally varies from about the middle (2.5) at idle, to about the top (5) at RPMs over 2000 or so. If the sending unit is original, by all means, replace it (about $30). If it is new, like about a month ago when the problem started, try reversing the wires on the sending unit.
jmd_forest
86 944 NA - Brought back from the dead
Old 07-08-2008, 08:45 AM
Not sure about the fuel consumptions or the grammar ?
In regards to the oil pressure...more than likely a bad connection. Check the wires and make sure they are clean...?
1990-Porsche 944 S2 Project Hair Loss
2001-Saab 9-5 BSR Best car I have owned
2008-BMW 328i (Just another beamer)
Old 07-08-2008, 08:48 AM
shivered's Avatar
Cking1975 : fuel consumptions (my fault...poor french canadian)
jmd_forest: I will try that
For problem #3 , it append every time (cold or hot) maybe a will change the sending unit ..I never change it
Old 07-08-2008, 09:31 AM
Back from Beyond
Greetings to a fellow Canuck!
You could, pull your spark plugs and have a look. Maybe an injector or two is stuck open. If they're all wet, then check the FPR as above.
For the charging issue you could also clean every ground connection you find, especially between the battery and ground. Adding a ground strap from the battery to the engine block helps, too.
I'd check and clean the wires to the oil pressure sender before I laid out the coin for a new one.
Beware of Rasta - he plays guitar in an immoral band.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 07-08-2008, 10:39 AM
Send a message via ICQ to bud9344 Send a message via AIM to bud9344
What kind off car and year ?
Charging system might have something to do with all the problem
Old 07-08-2008, 10:54 AM
I take it, it is and 85.5 & up car, by the volt meter on the dash.
Solve the problem one thing at time, first off all check your charging system with a volt meter never trust the volt meter on the dash it have been know to be off.
Whenever the Battery has a low voltage, every electrical thing in the car also get low voltage.
Good Luck
Bud
87 930 Black
86 951 Black
86 944 N/A Red part car
87 944 S White
83 944 N/A Black
83 955 N/A WHite Auto
Old 07-08-2008, 11:19 AM
Good Luck
Bud
87 930 Black
86 951 Black
87 944 S White
83 944 N/A Black
