How do i get this panel out?
How do I get this panel out. It is on the right side of the passenger's foot well. I need it out to fish new speaker wires into the door.
Old 07-13-2008, 06:05 PM
just start tearing s#it out.
tip for reinstalling those accordions -- hook part of the lip onto the sheet metal and twist it on. be sure to pull the wire tight before closing the door though, otherwise youll have to start the whole thing over.
Old 07-13-2008, 06:19 PM
But then all the s*it is torn up.
Old 07-13-2008, 06:21 PM
Z06C5R's Avatar
I just did that last week... Unfortunately you really have no choice but to tear it out because it's all glued in there, and then all that black plaster stuff on it cracks and falls off too. Fortunately the hole for the wire is only about 3 inches in, so you don't have to move much. Besides, the carpet will cover it all up when your done anyhow.
If you really want to keep it clean and factory-original or whatever, you could try sliding a long, thin blade of some sort between the inside face of the body and the insulation, then gently pry it up enough to get at the access hole. But that plaster crap is BRITTLE, so be careful.
1985 Porsche 944 - '85/1 N/A, currently for sale.
1971 Datsun 240Z - Street / AutoX car.
2005 MINI Cooper S - Insane daily driver
Old 07-13-2008, 06:32 PM
guees I will try that in the morning.
Old 07-13-2008, 06:35 PM
Nobody Special
I just fished the speaker wire over the top of the panel with a coat hanger (the bellows piece was pulled off the frame at the time) but I had the glove box out. I ran new speaker wire and a #1/0 feed along the sill to a distribution block for two 1000W amps attached to a folding rear seat delete/6.5" speaker project I was doing. As previously said, the carpet will cover most mistakes if you have to pry it loose.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 07-13-2008, 08:56 PM
got that panel out and ran the new wires. Any suggestions for the other side?
I used the special tool BFK. It came in the floorboard of the parts car I bought.
Old 07-14-2008, 09:49 PM
