-   -   A/C Question, a new one (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/419923-c-question-new-one.html)
shikzachaser 07-14-2008 05:40 PM
I have a weird problem that someone has to have a cure for. When I accelerate w/ the A/C on it quits blowing out of the vents. I can hear the fan blowing air but it sounds like a damper or something blocking the flow into the car. As soon as I let up on the gas it blows ice cold again. With the 134 conversion you could freeze meat in the car.
bud9344 07-14-2008 08:09 PM
That is an easy fix !
You loose vacuum when you accelerate.
And since the AC door is control by vacuum, when you loose vacuum the door change direction(close the AC)
http://forums.pelicanparts.com/uploa...1216094186.jpg
There is two one way valve on the brake booster. Black /Blue valve is for your AC.
Check your vacuum valve black/blue on the Booster brake.
Bud
87 930 Black
86 951 Black
86 944 N/A Red (parts car)
87 944S White
83 944 N/A Black
83 944 N/A White Auto
944turb0 07-14-2008 08:46 PM
I have a question. If they AC valve isnt on the booster where else could it be? I found my AC valve inside my glove box and I cant figure out where it went. My car has always had a problem with the vents blowing hot air when the car is running. Oh, sorry for hijacking your thread, lol.
bud9344 07-15-2008 02:30 AM
What year car is it . Porsche might put it any where in the engine bay.
Like on the 83 944 N/A, the vacuum is from the intake manifold (pic. 1). And on my 86 951 see pic 2. http://forums.pelicanparts.com/uploa...1216116577.jpg
http://forums.pelicanparts.com/uploa...1216116692.jpg
Give a picture off the engine bay around the brake booster, maybe I can figure it out where yours will be
Bud
87 930 Black
86 951 Black
86 944 N/A Red
87 944 S White
83 944 N/A Black
bud9344 07-15-2008 02:32 AM
Here is another picture on my other cars
bud9344 07-15-2008 02:34 AM
http://forums.pelicanparts.com/uploa...1216117986.jpg
87 944 S WHite
http://forums.pelicanparts.com/uploa...1216118036.jpg
