Can anyone advise me on how to remove without damaging paintwork and install new seal to quarter window.
1984 Porsche 944 5 speed manual right hand drive. |
In the Fires of Hell.....
Great title to your post
![]() ![]() You place the palm of your hand on the window on the inside, and gently but forcefully push outwards until the window pops out. Replace the seal/whatever you want, and then get a length of that flat type nylon rope, wrap it around the seal. Get some liquid soap to help, and apply pressure on the glass on the outside pushing in while you use the rope to pull the rubber seal into position. It may take a couple of tries, but it is not that terribly hard to do. Good luck, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
don't forget to have someone catch the window as you push it out...
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme '88 951S - zermatt silber/black - staying stock. purchased in 11-2006 '84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001 2021 Tesla Y - to get me to work |
