I am pulling my 86 944t motor to replace my rear main seal, timing belt etc. Any suggestions on what else I should replace while the motor is out. Motor has 100k on it, I plan on running high boost. I am also going to try and install a Findanza flywheel. Thanks for the help !!
Trying to work for parts!
Might as well do the rear cam tower gasket, as well as all the front end seals. Dont forget about the races/sleeves cause they get groves over the years.
Might not hurt to do the cam tower gasket while your there. Oh and you will need new intake manifold gaskets as well.
86 Metallic Grey 85.5 Metallic graphite - Gone |
Replace the o rings at the end of the balance shaft covers, they will start leaking after a while. You will have to remove the covers to replace them. Use locktight to "glue" them back on.
1983 944 RHD Original. Uses all my spare cash! 1947 Morris Sold 1972 Benz Sold 1975 Benz Sold 1976 Benz Sold 1977 Benz Sold |
Might want to think about doing your oil pan gasket as well.
Also throw in new motor mounts as well. Oil pan gasket as mentioned above. Royal pain to do.
