meister member
speedracing944's Avatar
looking for almost new (slightly used) clutch friction disk
As the title suggest I am looking for a friction disk which is in almost new condition with little to no wear. I am trying to get my car back together on a tight budget and this is one of the high dollar items I might be able to save on.
The engine is a N/A 1985.5
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 07-18-2008, 04:47 PM
flash968's Avatar
never ever ever reuse a friction disk, unless you are using the same pressure plate and flywheel it was used with (even then it is a bad idea)
like brakes, clutch disks put deposits on your pressure plate and flywheel - like brakes, they bake in together - like brakes, you need to start with clean surfaces and new friction material - like brakes, if the surfaces are extremely smooth, and show no signs of blueing, you can generally get away without surfacing them, but the friction disk needs to be new
find other ways to save money - that one is a bad idea
Old 07-18-2008, 04:53 PM
meister member
I have the surfaces on the pressure plate and the flywheel stoned and clean. There is no evidence of abuse what so ever. As with using a slightly used friction disk I don't see the big problem. You still have to let them bed in just like brakes and even a "new" clutch would have to bed in the same.
Speedy
Old 07-18-2008, 05:11 PM
With the amount of work involved in doing a clutch job, you don't want to go back in there again. Do it once the right way and forget about it for a long time and you will enjoy driving the car longer.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 07-18-2008, 05:16 PM
Proprietoristicly Refined
John_AZ's Avatar
Speedy,
An option for a used disc:
www.944Ecology.com
George has great knowledge.
OR
http://dcauto.gotdns.com/illustration/index/27787388
There are a few more in the CA area as well.
John_AZ
1988 924S + 1987 924S
Old 07-19-2008, 06:08 AM
meister member
I measured the friction disk which came off the parts car and it was under the wear limit by 1.00 mm. The one in my '83 has 70,000 miles on it and I don't anticipate it being in reusable shape.
If I can find a clutch which is worn less than 10% for a fraction of the price I would be a happy man.
Old 07-19-2008, 06:12 AM
Spievy's Avatar
Try ebay, I found a 3 piece Sachs kit for $400 I think, came with clutch disk, throwout bearing and pressure plate.
1975 - 914 1.8L Dual Weber 40's & MSD Ignition
1986 - 944 2.5L (SOLD)
Old 07-19-2008, 07:12 AM
Send a message via AIM to bholmes
just buy my 944 for cheap and then use if for a perpetual parts car. It has a new clutch in it. I think my friction was around $250....i thought that was pretty good, but it's still pricey when compared to other cars.
Brian
'86 944 NA
'94 Jeep Cherokee 3" and 31's
'86 Chevy C10 425hp
'98 Dodge Neon (the wife)
Old 07-19-2008, 08:59 PM
Greasy Member
many944s's Avatar
^Just what Speedy needs.... another 944 to work on
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 07-20-2008, 05:51 AM
