Desert Fox's Avatar
Squeaky Belt
Ok, so I drove my car for the first time after getting the timing belts changed and a/c charged tonight. The Problem I had was that the alternator/ ac belt is squealing.
Does anybody know how to remedy this?
Plus I was wondering where to find new motor mounts. mine are shottt.
83 944 Maroon
87 944s parts car (sold)
92 Ranger Lifted
Old 07-18-2008, 11:12 PM
Makis's Avatar
If the belt is too loose it will squeal. Tightening it a bit could solve this. Do not over tighten it though.
Old 07-19-2008, 12:11 AM
thoen's Avatar
i just posted on another thread...
my belt squeeked (horribly!) i replaced it and tensioned it correctly but the noise remained only when the ac goes on. the culprid on mine is the ac compressor.
yours might only need replacement ( a pain in the ...) and tensioning.
Yellow 1983 944. Many alterations, modifications, repairations and aberrations. Great car!!
Old 07-20-2008, 06:45 AM
Desert Fox's Avatar
Well I figured out why it does. I went to tighten it, and took my skid pan off only to see in horror that there was no bolt on the tensioner on the engine end. I didnt have a bolt at the moment, so I decided that im going to take the car back into the shop where I got the timing belt done Monday, and have them put it back in. In the meantime I tried loosening it, so I could fit a bolt, but I couldn't make the tensioner fit.
Anybody have a suggestion on how to loosen it? I am trying with a 17mm open wrench, and it worked a little, but at the first sign of it stripping I stopped.
83 944 Maroon
92 Ranger Lifted
Old 07-20-2008, 11:45 AM
