-   -   AC compressor stays on when button is out (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/421179-ac-compressor-stays-when-button-out.html)
pinetreeporsche 07-21-2008 04:16 PM
Car's a '90 S2: When I want AC, I push the button with the snowflake; it gets cool. When I push it again, and it pops back out, it keeps on cooling. Is there a relay that might be stuck or something? I hate to burn gas and wear the compressor out when I don't need to. Anyone know anything about the AC system? Thanks....
running_cold924 07-21-2008 07:01 PM
there is a relay in the fuse box under hood, should be sorta clear.....and you can also remove the a/c button but is a pain to reinstall. just be prepared for springs and ball bearings to pop out. may just need lubed, might be sticking...try the relay first.
phoenix_iii 07-22-2008 11:58 AM
I have a 'Recirculation' button that DOESN'T stick
Takes me about 10 tries to get it to stay in, and the flaps open/close each time I press it.
Is THAT just the button? =\
SmileWavy
hpservertech 07-22-2008 01:18 PM
yes, that is just the button. Known to happen.
pinetreeporsche 07-22-2008 02:26 PM
Amazing-- my recirc. button wants to stay on, won't pop out the first few tries. Where do I look to watch the flaps moving?
pinetreeporsche 07-22-2008 02:27 PM
phoenix_iii 07-23-2008 06:38 AM
You can hear them with the car off. =)
