New User- Be Gentle
Attention Arnworx users/owners
Being the talented and overly bright individual I am, I lost the paper that I recorded my timing belt readings on. My timing belt is not new but it's not at replacement age either. What should my tension read on the arnworx tool?
Thanks guys!
1983- 944 5spd- For sale!
2008- Nissan Titan, Gas Guzzler DD
Old 07-21-2008, 05:42 PM
For a used cam belt you add the deflection value of +.198 to your initial reading to get the ideal setting. The acceptable range is +/- .009
For a new cam belt you add a deflection value of .173 and the range is +/- .007
Hope this helps
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 07-21-2008, 05:57 PM
Professional Bull5hiter
Outback Porsche's Avatar
You can find a new form here;
http://www.arnnworx.com/Images/Tools/920X_Inst_V313.pdf
Jeff
83 944 Guards Red
23 718 GT Silver
Old 07-21-2008, 06:30 PM
New User- Be Gentle
I must be confused, so do I not need to know what the tension on the belt was before I took it off? All I do is record the value using the reference bar and then remove the bar, add .198 and that's the right tension?
When I press on it, how tight should the belt be?
Old 07-21-2008, 06:54 PM
Aufenbahn's Avatar
Yes it all refers back to the reference bar - so naturally it's called a reference bar. All kidding aside just follow the procedure on Arnworx website and tension the belt as shown there. Unless your belt is less than a year old for my money, I'd replace it. Good luck
Andy D.
Currently driving 2005 Audi A4
Currently driving 2006 Ram 1500 sometimes
Old 07-22-2008, 12:29 PM
