-   -   how does this even happen (endless overheating) (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/421319-how-does-even-happen-endless-overheating.html)
John_AZ 07-24-2008 06:54 PM
Your in Texas, put in a cooler thermofan switch and put the thermostat back in
with the correct shim and gasket for your car!
From picture: C clip--shim--outer thermostat gasket (2 thickness sizes available )--thermostat--inner seal (ignore now).
http://forums.pelicanparts.com/uploa...1216950612.jpg
GL
John_AZ
BananaClip 07-24-2008 08:38 PM
does it matter what kind of thermostat gasket I use? should I go with a lower temp thermostat if I'm using a cooler thermoswitch?
John_AZ 07-24-2008 10:23 PM
I use a cooler 71C/160F degree thermostat with a 75C/167F degree thermofan sw. You may only have to drop one level and go with a 82C/180 thermostat and 92C/198 thermofan switch with a newer radiator.
The gasket thickness depends on the pump you have either a 4.5mm thick outer or 2.5mm thickness. NAPA usually has both sizes.
GL
John_AZ
John_AZ 07-24-2008 10:38 PM
Bump, edited and saw you were on.
John_AZ
