Tie rod removal tool
I'm about to do my first tie rod removal myself to avoid a $290 fee to pass inspection. I have never attempted this and have researched this site and others and found that a tie rod removal tool is the best way to remove the tie rod (go figure). However, my local advance auto stocks something called a "tie rod remover" but it looks like a giant tuning fork, and NOT like what I figured it would look like.
This is what I thought the tool I needed should look like: ![]() This is what Advance Auto stocks, a long rod with a fork at the end (with no extensions like the picture shows): ![]() Which should I be getting and is the job really a 20 minute job?? THanks! |
Just thinking out loud
Neither? The pickle fork is the proper tool for separating the tie rod ends from the steering arm, and for ball joints. I haven't had a need for one on the 944, or my other cars. Actually I destroyed a pickle fork trying to separate the ball joints on my Land Cruiser. Heat and a BFH gets it done every time.
83 944 91 FJ80 84 Ram Charger (now gone) |
Just a good hammer will do.
Greasy Member
+1 on the BFH.
There is a tool similar to what you have pictured that is basically a "2 jaw puller". Like any stubborn mating surface, a sharp impact is the best way to separate, a "slow" increasing force will rarely do the job! In fact, I have seen the "2 jaw" style mushroom the stem so much that once it is loose, it needs to be ground down just to pass through the opening.
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
Trying to work for parts!
+2 on the BFH. The fork will work too. But sometimes the tie rod ends get stuck in there.
86 Metallic Grey 85.5 Metallic graphite - Gone |
That Guy
It may not matter, but pickle forks will usually damage the dust boots. I have had very good sucess with this tool available at most chain auto stores.
![]() Just make sure you wear eye protection.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Yeah, need for the tools, just another way for them to get money. Its a real eay straight forward job, what would you guys say? 15 minuets a side? Last time I did mine, pass. side came right off and on, but the drivers side was rusted on and I had to sawzaw it off, that took a while. And when I put the new one on, the arm was just spining around when I tried to tighten the end on. The drivers side took a long time to do, some cursing, and a few brewskies. Have fun and good luck.
Steve- If you havent looked, look- www.clarks-garage.com 87 951 red- Maria (current) 84 944 white- Percilla (current DD) 85.5 944 red- Pinta (past) 87 924S red- Nina (past) |
Whats with the paint techno? So you know where to stop tightening it on, or you repaint the Koni's?
That Guy
The car is my daily driver so i was trying to get the toe back reasonably close with the new tie rod ends. The place i usually goto for wheel alignments didnt have time to do it until a couple days afterwards.
To keep the tool from slipping on the tie rod end, I leave the loose castle nut on .
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
