fast924S's Avatar
Send a message via AIM to fast924S
Pics of engine
Well, Im still not done, As some of you may have noticed I am looking for a external oil cooler, The 2 I have do not fit well, SO off to call Mocal. But I did take some pics of the engine installed only have one uploaded, I still have to install the radiator and hoses and the exhaust header, I havent done this just so I can have room to play with the oil cooler and lines. Also I didnt get a good pic of my ignition system, I will be posting more pics here soon.
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 07-27-2008, 04:38 PM
Proprietoristicly Refined
John_AZ's Avatar
Excellent work!
I also enjoyed the CarDomain site. The car looks great.
I have a shortcut for your cardomain.com page. The link above did not work for me.
http://www.cardomain.com/ride/723719
Great job.
John_AZ
1988 924S
1987 924S
Old 07-27-2008, 04:53 PM
What kind of MAF thingy is that?
Old 07-27-2008, 06:02 PM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
That is nice! I have a mocal mounted under the header panel. 12? row I think, 15 maybe? I forgot, but its big.
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 07-27-2008, 06:36 PM
fast924S's Avatar
Thanx Guys, The Maf is a Old Huntley Racing MAF, same kit sold my Split second
http://www.splitsec.com/ Its the universal MAF 3.0A under maf kits. Works great. Thanks for the updated shortcut. Just remember those are older pics before my rebuild, Her is a List of things done to the car this time
1. swap from 9.5 to 1988 10.2 CR
2. JM camshaft
3. 951 valve springs
4. Rebuilt head
5. 5 angle valve job
6. Port match TB to Intake and Intake to head
7. LR adjustable cam gear
8. LR adjustable FPR
9. LR spark plug wires
10. AC delete
12. Spec light weight flywheel
13. Spec stage 2 clutch
14. FULL bottom end balance
15. LR underdrive pullies
16. MSD SCI digitial Plus ignition
17. Blaster 2 coil
18. Header wrapped and sealed
19. 4 new injectors.
20. 951 oil cooler housing
21. LR oil catch can
I also have some minor things I will be installing after I get her running. I got a full led dash light kit, a Wide band 02 system I need to install and a MAFTERBURNER kit from LR that I need to install and a WET NITROUS KIT. But I think I will just get her running and broken in first on the Stock DME and no nitrous for now.
Ohhh yea Here is a pic of the Bursch Header wrapped but not sealed yet
ANd A bad shot of the MSD Digitial SCI controls
Old 07-27-2008, 08:21 PM
very clean work
Old 07-27-2008, 09:30 PM
Schumi's Avatar
I want to do stand alone ignition on my other car so bad. If I don't make it to 944 spec, I'll stick running in SCCA F-prepared which means it will get an MSD ignition module with launch control....
Did you have to change anything with the ECU when you changed compression? When I do my rebuild I may swap for the '88 pistons.
M
Old 07-27-2008, 09:33 PM
fast924S's Avatar
No the Stock ECU should be fine. AT the moment I do have the FR-wilk PP2 installed, But since its for a 1987 engine WIlk advised me not to run it with 1988 10.2 pistons due to the fact that it might have to much timing advance and to switch to the 1988 PP2. But Im not sure what Im gonna do yet. I might sell the chip and my Mafterburner http://www.lindseyracing.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=LR&Category_Code=944MAFTERBURNER
And go with the Russell Berry maxtune or whatever its called.
Old 07-27-2008, 09:41 PM
Politically Incorrect
onZedge's Avatar
Did you have to do any special modifications to install the adjustable cam gear?
Edek
'87 924S
'91 535i
Old 07-28-2008, 05:16 AM
fast924S's Avatar
Nope, I installed the LR adjustable cam gear the same way you would any other cam gear. They said you have to mod the cam cover but I didnt need to, It fits fine so far
Old 07-28-2008, 02:07 PM
meister member
speedracing944's Avatar
I can't wait to hear your driving impressions of the engine. The engine I am putting in my car will have the Bursh header wrapped like yours with a straight through exhaust. I am toying with the idea of going with a webcam regrind as well.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 07-28-2008, 05:19 PM
Aslet's Avatar
If you don't mind me asking, how much did this "little" project put ya back? I have seen you on the boards and know you have your stuff squared away, so I'm sure this is a complete and will kick some butt! Also, why did you wrap the headers? I know with a turbo, it is good to keep the heat in the pipes to increase the turbo's power, but on a NA car, what does it do, just help the gases move through the exhaust more efficiently?
-Randy
-Randy
1984 944 -Race car project
1993 968 coupe- Amazon Green
Old 07-28-2008, 06:31 PM
Wrapping or coating the header should keep engine bay temps lower, which can be a good thing in the long run. Maybe there are other benefits?
I'd like to get mine coated... mostly just so it doesn't look like a big rusty mess.
1987 944S
Old 07-29-2008, 06:16 AM
meister member
It is suppose to keep gas velocity high therefore increasing scavenging effect = horsepower
Speedy
Old 07-29-2008, 09:51 AM
fast924S's Avatar
Well I have had the car since I was 16, Im now 25, SO almost 10 years. I dove it for about 7 of them then I had it apart for about 3 years, I never really kept trap of the cost, I just picked away at it. I know everyone says WHY WASTE MONEY ON A NA when you can get a turbo. I say SCREW THAT. I love my NA, I love playing with it. I love the exhaust note. The car has way to many memories and hard work/ blood into it to every get the right money back if I ever sold it. SO I made it my little project and whenever I got some extra cash for Xmass/birthdays/side jobs I would pick up a new part for the Porsche and over time it came to be what you see now. So I never really added it all up but all together Im sure its a retarded amount of money and time. But I do it for the fun of it and to make it drive the way I want it to, Not to hold resale value or anything like that.
I wrapped the header because as noted, It will reduce under hood temps and it also helps speed up the exhaust to help the scavanging effect thus making a tiny bit more HP (I hope). You can also coat them which is usually better then a wrap I just didnt want to wait for them to be shipped out then coated and then returned.
Just so you guys know, I dont think this is gonna big any BIG hp engine as I didnt build it for that, I just wanted to improve what was already there and maybe give it a little more kick in the pants on the way. Its really a big experiment, SO many people said you cant make HP in a NA, I said hey why not give it a shot, If it works and I make around 170-180hp I would be surprised and excited, But if it doesnt I still have a very cool 924S ( I think). Most of the stuff I have done is Bolt on or drop in/swap, I didnt want to go crazy and do alot of machine work like big bores and strokers and I didnt want the head Ported sooo much that I only made power in the way upper RPMs. I think my choices should make a very good balanced engine.
SpeedRacing- Yea Im super excited to get it done, Its just this Freaking stupid oil cooler is breaking my balls and I havent had a chance to go take measurments for the lines ect.... Anyway I know JM cams are expensive but they are a FRESH/NEW cam not a regrind ALSO Jm offers many more options then the WEBB cams do, I think WEBB only offers ONE grind for the 944, while JM has 3 drop in go cams and 2 or 3 that need mods I believe. Its something to look into, LEt me get mine running and I'LL tell you how it is before you go and buy. I like the exhaust setup, Just be ready for the Bursch header, The Paint job they do when they send it to you SUCKS!!! and burns off in 2 seconds then it gets rusty, Also I did have a slight fitment issue that I need to grind a little bracket under the car that it was hitting, but no big deal. Also The exhaust is gonna be loud, I am running the bursche header with cat sub pipe and a B&B catback, I like the sound, High in the RPM's it kinda sounds like a F1 car
Old 07-29-2008, 02:21 PM
MakeshftPatriot's Avatar
I am curious about the MAF kit for the S2 application, I cant stand my bulky stock one. Do you know if it works?
91' 944S2-Traded|87' 944-Traded|84' 944-DD
Old 07-29-2008, 02:43 PM
fast924S's Avatar
Not sure, But I would think if it Works on a 8v NA then it should work on the 16v NA, Its the same type of AFM, You would just have to figure out the wiring and then tune.
Old 07-29-2008, 02:50 PM
Custom User Title
mikepellegrini's Avatar
It all looks very lovely.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 07-29-2008, 06:56 PM
