rebuild
Help guys!
I just removed my oil pump and find that the crank has been driving into the back of the oil pump and has worn rings into the back of the pump. Do we have a shim or something that deals with end play on the crank that will alleviate this problem? Has anyone else found this in their engine?
03 Silver PT Turbo - Ours 86 White 951 - His 86 White 944 Manual - Hers 98 C-4 Sons 86 Gold 944 Auto - Sons 84 Maroon 944 Auto - salvaged 78 Yellow 924 - found a new home |
Do you have a photo?
86 944 NA 2.5 |
Nobody Special
AFAIK the thrust bearing on the crank is about the only way to really control endplay. That probably requires much more work than you were planning on though unless you pull the engine.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD 91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD 86 - 951-K26/8, daily driver-SOLD 87 - 944S - Another daily driver-SOLD |
Politically Incorrect
Without actually seeing a picture, it sounds like the car was driven with a loose crank bolt at some point, but, well, I haven't seen a picture...
Edek '87 924S '91 535i |
Just thinking out loud
It can happen if the wrong woodruff key was inserted prior. Mines a stub nose crank w/ no power steering, and the woodruff key is different from the later cars. The later cars are quarter moon shape. No B/S, saw both today. Change happened mid 83.
83 944 91 FJ80 84 Ram Charger (now gone) |
