Kirby2's Avatar
rebuild
Help guys!
I just removed my oil pump and find that the crank has been driving into the back of the oil pump and has worn rings into the back of the pump.
Do we have a shim or something that deals with end play on the crank that will alleviate this problem?
Has anyone else found this in their engine?
03 Silver PT Turbo - Ours
86 White 951 - His
86 White 944 Manual - Hers
98 C-4 Sons
86 Gold 944 Auto - Sons
84 Maroon 944 Auto - salvaged
78 Yellow 924 - found a new home
Old 07-04-2007, 05:55 PM
Do you have a photo?
86 944 NA 2.5
Old 07-25-2008, 10:16 AM
Nobody Special
AFAIK the thrust bearing on the crank is about the only way to really control endplay. That probably requires much more work than you were planning on though unless you pull the engine.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 07-25-2008, 11:32 AM
Politically Incorrect
onZedge's Avatar
Without actually seeing a picture, it sounds like the car was driven with a loose crank bolt at some point, but, well, I haven't seen a picture...
Edek
'87 924S
'91 535i
Old 07-26-2008, 11:47 AM
Just thinking out loud
mattdavis11's Avatar
It can happen if the wrong woodruff key was inserted prior. Mines a stub nose crank w/ no power steering, and the woodruff key is different from the later cars. The later cars are quarter moon shape. No B/S, saw both today. Change happened mid 83.
91 FJ80
84 Ram Charger (now gone)
Old 07-26-2008, 07:37 PM
