-   -   How did you get your inner thermostat seal out..... (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/423205-how-did-you-get-your-inner-thermostat-seal-out.html)
iamchappy 08-02-2008 10:57 PM
SmileWavyI am up for the challenge, I screwed up in trying to hook the bugger out of there and messed it up before i realized that it wasn't just a rubber seal:mad:, I have all of the external rubber off but the metal sleeve is still there, How did you get yours out- Dremel tool , screw driver, punch, needle nose, huge easy out:confused:...........
nynor 08-03-2008 04:07 PM
picture? i am trying to figure out, from memory, what you are talking about, but can't arouse those particular brain cells.
iamchappy 08-03-2008 05:31 PM
Ok this is the easy and painless way to remove the inner seal.
Purchase a 1 inch internal pipe wrench found in the plumbing section of your local hardware or builders store for about ten bucks. The one i purchased had to have about 1/2 inch ground off the end to allow the expanding cam to grip it but i have seen others that look like they would work straight out of the box. Only a few twists and it was out! I cant stress the usefulness of the Snap On snap ring tool also, easy in easy out.http://forums.pelicanparts.com/uploa...1217809870.jpg
iamchappy 08-03-2008 07:35 PM
like this...http://forums.pelicanparts.com/uploa...1217817309.jpg
