How often do you add oil to your 944?
Hello all,
I know this will vary by model, driving style, mechanical condition etc. but I was wondering how often you guys add oil to your cars. Is there a factory tolerance of any sort on how much the car will burn? Just curious.
Old 08-05-2008, 09:46 AM
Greasy Member
many944s's Avatar
The factory manual shows "tolerable" oil consumption to be 1 liter per 1000km (up to 1.5). I have seen several cars where this holds true to. However, I personally have never experienced any noticeable consumption by my '44.
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 08-05-2008, 10:15 AM
Not Special
I tend to check mine and top off if necessary for the first week after a change. I've been checking since I changed it about 2 months ago - I've lost nothing and it's a DD.
Current: 1989 Porsche 944 S2 - Baltic Blue/Linen
Former: 1985/1 Porsche 944 - Graphite/Black
Old 08-05-2008, 10:20 AM
That Guy
Techno Duck's Avatar
My '87 n/a burned about 1 quart ever 3500 miles or so. That was with alot of high RPM track stuff aswell as daily driver. I would say over half of that loss was due to leaks from the oil fill tube o-rings and the front crank seal. After replacing all of those seals the loss was cut down quite a bit.
My 951 if anything is losing some oil past the turbo seals. I would say less than 1/4 a quart after 3500 miles.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 08-05-2008, 10:39 AM
Misunderstood User
I agree with Nick, Wipeout and Jon, I don't loose much if at all. I'm not leaking and use 100% synthetic oil. I don't add any between oil changes.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 08-05-2008, 11:39 AM
Toofah King Bad
Rasta Monsta's Avatar
My S uses/leaks zero, 114k miles.
My 931 on the other hand. . .
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 08-05-2008, 11:44 AM
Spievy's Avatar
Maybe a 1/2 to 1 quart between oil changes (3000 miles).
1975 - 914 1.8L Dual Weber 40's & MSD Ignition
1986 - 944 2.5L (SOLD)
Old 08-05-2008, 12:50 PM
Custom User Title
Dave L's Avatar
half to one quart between oil changes
Old 08-05-2008, 03:09 PM
PXJ800's Avatar
No leak from my 84 DD either, thankfully. Well, oil at least.
'84 944,
http://photobucket.com/84porsche944
Old 08-08-2008, 08:59 AM
92 968 - I use about 1/2 quart over 400 miles of on-track driving and none getting there or back.
Tom
92 GP White 968
Old 08-08-2008, 10:24 AM
Schumi's Avatar
I put only about 2000 miles a year on my car but it never leaks nor consumes any when I am driving it during the summer. The front main seal leaks only when I do not drive it for long periods. Taking it out for a drive once a week keeps it from ever dripping any.
M
Old 08-08-2008, 11:58 AM
Aslet's Avatar
I drive my car almost every day, not far though. It has 214,000 miles on it, but was well maintained. I change the oil every ~3000 miles, and I use natural 10w/40 oil. I check it usually every other week, and on average I add maybe 1/4 Qt of oil between changes. Using some oil is not necessarily a bad thing though. If you don't have to add a huge amount between changes and oil isn't leaking into other systems, then its all good. My mom's 2002 Jetta uses about 2 Qt every 5000 miles, that thing goes through oil. YMMV
-Randy
1984 944 -Race car project
1993 968 coupe- Amazon Green
Old 08-08-2008, 02:09 PM
