Fuchs fit?
Does anyone know if a set of 7x15 and 8x15 Fuchs from q 1986 911cabriolet will fit a 85.5 944?
I think they have similar offsets....guys?
yes. i think. ;) they fit on my '83 with spacers, so i think they'll fit the later offset.
Direct bolt-up.
The 944 didn't switch to the late offset until 1987. |
right. thanks for the info about the late offset. i can never keep that straight.
Thanks for the quick replies. I did find a chart on rennlist and it confirms what you all said. 23 mm front offset, 10 mm on the rears. Direct bolt on. I appreciate the help.
The 944's optional 7 & 8 x 15 Fuchs have 911 part numbers. Not only are they interchangeable, they're the same part.
| All times are GMT -8. The time now is 10:00 AM. |
