need part numbers for early vacuum lines
Does anybody have the part numbers for the early vacuum lines under the manifold?
I Just replaced all the vacuum hoses recently. Here's my list;
Qty 1, 944-107-187-01 Breather Hose from Oil Separator, 924S, 944 (through 1987), 944S Qty 1, 944-110-361-03 Vacuum Hose, 944(1982-85) W/M573 Qty 1, 944-110-178-00 RUBBER HOSE Qty 1, 944-110-177-00 RUBBER HOSE Qty 1, 035133753A Venturi tube Qty 1, 999-239-011-40 Hose Qty 1, 944-110-173-00 Hose Qty 1, 944-110-187-01 Hose Qty 1, 944-110-182-02 Hose Qty 1, 944-355-401-00 Hose Qty 1, 999-181-152-50 Hose, 7,5 X 13,5 Qty 1, N0203621 Hose, 12 X 2,5 Qty 2, 928-573-727-02 Distributing piece Qty 8, 928-574-717-02 Hose Qty 1, N0201391 Hose, 4 X 1 Suggest replacing all your hose clamps also. You can also get kits from Lindsay Racing for the 4mm Vacuum hoses. If you went this way, some of the hoses above are redundant. I chose to keep it original. Cheers |
Unless you have a hole burning in your pocket go with the lindsey kit. Much more economical and I dont see how you would ever have a vacuum leak again with it.
http://forums.pelicanparts.com/uploa...1218522322.jpg
Ok. 94411017800 (29), 94411018701(21), and 94411017300(13) are the three that the Intake manifold needs to come off to replace right? What about 94411017700(15)? Basically, I've found a cracked vacuum line under the manifold, and if I have to remove all that crap to replace it, I only want to do it once. Should I replace that expensive sucker, 15 in the picture too, or can that be accessed later without removing the manifold, etc? I'd like to try to get all the parts I need, before starting this. I know I need intake manifold gaskets, too. anything else? I also want to make sure I have the right part numbers before ordering. Our host has the three for 14, 21, and 21.75, any place cheaper. I checked 944online and there are about 25 each. This comes at a crappy time, since I'm running a little low on funds. Too many projects at once. |
the only kit I saw at lindsey racing was for the smaller lines, and that is a project for a later time.
Yeah, I replaced the J-hose (15) too. Must have edited it off my list. I actually got my kit from 944Online. If I remember correctly, it also comes with the 4mm fittings and hose (and venturi).
Cheers, |
The 944Online kit gives you the basics (probably what you want). The 944Online kit didn't have all I wanted and I ended up getting the rest from PP.
Thanks for the info, you've been a big help. One more question, is this the kit you ordered from 944online?
http://www.944online.com/cgi-bin/ASI_Store.cgi?Product+skukey_1128446166+9441+fueld elivery-9441 |
That was the kit I ordered.
Cheers |
| All times are GMT -8. The time now is 01:42 AM. |
