Rockin' NW Arkansas
firefighter7128's Avatar
Send a message via Yahoo to firefighter7128
Hers one for the Gurus - Dash Electrical
I have a plethera of electrical issues. It may be starting here. As i drive and sometimes when stopped and occasionally when the car is off i can hear a clicking sound behind the gauges. sounds like a jacked up relay trying to do its thing. or maybe a bad flasher that doesnt work right. Flashers all work fine. What could it be? is there a relay inside the dash?
Matt
1986 Porsche 928 S - Daily Driver
1984 928 S - SOLD, 1986 944 S - SOLD, 1988 944 S - SOLD
Old 08-19-2008, 05:59 AM
Proprietoristicly Refined
John_AZ's Avatar
Matt,
The bold type-is this from your PSAs over at 92.1 KKEG?
Car problems, crazy drivers and lack of sleep.
I just solved my electrical problems with the '87. Replaced the alternator with a 115 amp rebuilt unit (90 amp stock). I did all the standard tests, remove old alt and take to shop for test-OK. New volt reg. Cables and ends OK. Problems continued...thermofan relay burned out, cooling fan relay contacts bad, fuel pump began to hum louder......
The higher amp alternator fixed my electrical gremlins. The old alternator, while testing OK could not keep up with the old aging car electrical system-my view.
Parts that began to draw a little higher amperage and old wiring and connections that were more resistive?
This may not solve the clicking in your dash. The gounds are the first place to start and then clean every connection. The fan cooler relay may be making the sound when it activates the fans.
GL
John_AZ
1988 924S + 1987 924S
Old 08-19-2008, 06:41 AM
Rockin' NW Arkansas
well i have gone thru all 7 ground points. i still dont have a window that goes down and all marker lights do not work on pass side. headlights and turn signals work fine.
Matt
Old 08-19-2008, 06:53 AM
John_AZ's Avatar
Windows. Usually the switch will not make ground. Some have success with carefully cleaning-when you open the switch springs will fly. New switches will fix but may only last a couple of years.
Side markers. Did you check the bulbs? These are 4W special- get from PP. Local parts houses may give you a generic 1393 bulb? Some generic get very hot and may not work.
Still sounds like weak alternator, VR or battery.
John_AZ
Old 08-19-2008, 07:01 AM
Rockin' NW Arkansas
Alt seems to be charging fine. All lights worked then all of a sudden they didnt.
Had a problem with rain water not draining and filling the batt and fuse box compartment.
batt seems ok. i have had it on a charger all night and still, no lights. bulbs Apear ok exept one which was rusted up. We removed that for now until we find the issue. will removing a bulb stop current to other bulbs?
Matt
Old 08-19-2008, 07:17 AM
Trying to work for parts!
Send a message via Yahoo to hpservertech
No it wont.
Check the resistance of the main ground cable from the battery to where it attaches on the block & belhousing.
I would also check the resistance of the main positive cable from the battery to the starter....with the battery disconnected.
Those cables crack on the inside and start to corrode, any napa store can make you a new one.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 08-19-2008, 09:26 AM
Oh, and on a late car there are no stock relays behind the dash. PO could of put one in for an alarm, but the stock ones are in the main panel in the engine compartment.
86 Metallic Grey
Old 08-19-2008, 09:27 AM
