Exclamation Engine removal help
I have all the steps finished for removing the engine...but I cannot get the steering shaft disconnected...any help would be much appreciated...
What clarks says to do...I can get anything to come off...
Disconnect the steering gear shaft using a punch and hammer. Be careful not to damage the splines on the steering shaft
1990-Porsche 944 S2 Project Hair Loss
2001-Saab 9-5 BSR Best car I have owned
2008-BMW 328i (Just another beamer)
Old 08-24-2008, 11:19 AM
meister member
speedracing944's Avatar
It usually is a PITA. I try to work it from underneath the car using a long screwdriver and a hammer tapping upwards. Spray it with WD-40 as well. You could also try to remove the shaft at the joint nearest the steering wheel. This joint tends to be less corroded.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 08-24-2008, 11:27 AM
Schumi's Avatar
I was an idiot and had dropped the rack before realizing the steering shaft was still connected. With lots of penetrating oil and a big flathead screwdrivers I wedged the coupler off the splines. After it got most of the way there I grabbed a big open ended wrench and used it like a pickle fork and popped it off. Because the rack was disconnected gravity assisted in this and it gave me some clearance to yank it better. Not sure if this is good for the rack but all seems well.
M
Old 08-24-2008, 11:47 AM
Nobody Special
Just a hunch, but have you removed the bolt at the clamp completely rather than just loosen it? I found that out after trying for 30 minutes to get the connection to pop loose. The lower spline has a groove for the bolt. Once the bolt was removed the rack section nearly fell off with a slight tap of a hammer.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 08-24-2008, 11:49 AM
Back from Beyond
^+1. That bolt needs to come right out. Then drive a cold chisel or big screwdriver into the clamp to spread it open. A good beating always helps...
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 08-24-2008, 03:56 PM
Thanks for all the HELP !
I lubed that POS up and let it sit overnight, I see If I can get it off today...rusty POS
Old 08-25-2008, 06:45 AM
