Custom User Title
mikepellegrini's Avatar
When a rubber-centered clutch starts to fail...
...what's it sound like?
I just bought an 86 951 that was non-running. It had sat since 2006.
I've got it running now, and put on new belts and rollers and a new TPS, and it runs great. I haven't got it off the jackstands yet so I don't know how it drives.
But when you shut it off, there's a metallic squeaking, scrtaching sound that sometimes comes from the bellhousing area - only when you turn it off, never when running, and only the last couple seconds before the engine finally stops. Not every time you turn it off, just sometimes.
The only thing I can think is that it's a rubber centered clutch in the process of failing (losing little bits and pieces which are rolling around inside the bellhousing). I can't imagine anything else loose in that area.
The PO parked it because of the TPS - he thought it was a bad head gasket (no power, wouldn't rev over 2K). He wasn't aware of any other problems, but if the clutch was failing and in limp mode, he might not have noticed.
Any ideas?
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 08-23-2008, 06:28 AM
meister member
speedracing944's Avatar
throw-out bearing or pilot bearing?
When my rubber-centered clutch failed it made no noise but wouldn't allow me to change gears. The rubber center was totally destroyed.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 08-23-2008, 07:04 AM
Misunderstood User
Speedy is probably right. Rubber cracks over time - I did not see mine coming until I could no longer shift. Be careful here because a rubber clutch can cause tranny damage.
If you do replace it, do not repalce it with rubber, go to a the spring design.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 08-23-2008, 07:22 AM
Custom User Title
I dunno, it sounds like something is loose inside the bellhousing - I was thinking of little pieces of clutch.
If I do replace it, I'd probably go for one of the Spec Stage 2 clutches from Lindsey.
The car's got 170K on it, so you'd think the clutch had already been replaced.
Maybe it's a spring centered clutch and it's loose springs rolling around that I hear?
16 Ford Expedition
Old 08-23-2008, 07:38 AM
meister member
There are a couple removable rubber inspection hole covers. You could pop these out and take a look inside the bellhousing.
Speedy
Old 08-23-2008, 08:31 AM
Toofah King Bad
Rasta Monsta's Avatar
Careful with the Lindsey clutch sets unless you really need the extra clamping force. . .they made my buddy's 951 go through forks with shocking frequency.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 08-23-2008, 09:38 AM
Nobody Special
The 951 models never used a rubber center clutch so you can count that out. It could be a disc spring loose as someone suggested or the TOB might be looser than it should be.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 08-23-2008, 09:57 AM
Custom User Title
I took the plunge - it runs and drives and boosts just fine.
The clutch engages really low - you let it out maybe an inch and it engages.
But there are no issues. Kinda a shimmy at about 60 MPH, but that could be tires - it sat for over 2 years.
It hasn't made the noise in quite some time. I gotta think maybe it was just a dead rat rolling around in there or something.
16 Ford Expedition
Old 08-23-2008, 02:14 PM
TibetanT's Avatar
Yeah, my vote is wheel out of balance for the front shimmy.
As for the noise, could possibly be the throw-out bearing or it could be a loose belt such as alternator belt not tensioned properly or power steering belt?? Just a guess on my part.
Hope this helps.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 08-23-2008, 05:24 PM
Composite Shop Owner, DJ
MixMasterK's Avatar
Send a message via MSN to MixMasterK Send a message via Yahoo to MixMasterK
Use a mechanic's stethescope to pinpoint the noise.
'86 944, 5 Speed (Daily Driver)
Old 08-23-2008, 07:00 PM
