-   -   2.5 & 2.7 differences (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/426982-2-5-2-7-differences.html)
dweymer 08-25-2008 02:13 PM
What are the differences in the 2.5 and 2.7 engines? What parts will interchange etc.
The search function won't recognize 2.5 or 2.7
Thanks,
D
zedsn 08-25-2008 02:47 PM
The 2.7 I believe uses a different water pump. The impeller is larger and will not work on a 2.5.
Techno Duck 08-25-2008 02:50 PM
Cylinder head has different water passages which only line up with the 2.7L block and 3.0L blocks. Cylinder head has larger intake valves aswell as oval intake ports.
