Rockin' NW Arkansas
Lets talk Door Window Electrical
ok, since i have bought this car, i have been unable to roll the pass side window.
I am in the works of trying to narrow down the problem and beleive i found that the motor is bad. i just need a 2nd opinion. ![]() I have already ruled out the switch by taking the working switch and using it on the pass side sockets. Didnt work. I tested the female side of the socket on the pass side window control and found that 2 of the 5 ports are hot. I dont know if that is standard, but assume so. I have 2 jumper wires but have not attempted to "hot wire" the female socket yet to see if the window will go down. Does anyone have a knowledge of what of the 5 wires coming off the pass side control are which? Input?
Matt 1986 Porsche 928 S - Daily Driver 1984 928 S - SOLD, 1986 944 S - SOLD, 1988 944 S - SOLD |
Trying to work for parts!
Why not just jumper the motor with a battery from a cordless drill?
86 Metallic Grey 85.5 Metallic graphite - Gone |
Rockin' NW Arkansas
i havent pulled the panel off yet. i try to never remove a dorr panel unless i have to. i can never get them on right or my clips break. lol. it will be the next step if i need too.
Sent you a PM
In the Fires of Hell.....
Hey, before you spend $$ on a new motor, understand that BOTH the Driver's side and Passenger's side swtiches need to be in the circuit and working properly for the window to work - They are in series.
If they are both good and things still don't work, then worry about your motor. Good luck, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Learned by do'n twice
Both the driver's side switch for the passenger window and the passenger side switch for the passenger window must be working for the passenger window to go up/down. If you clean both switches its a good bet it will work, if not, you've eliminated the switches as a variable in your problem.
jmd_forest
86 944 NA - Brought back from the dead |
Rockin' NW Arkansas
oh really. wow, that changes a bit of everything.
Wait, even if i have power to the pass side? 2 pols are hot, 3 are not.
Professional Bull5hiter
PM sent
Jeff 83 944 Guards Red 23 718 GT Silver |
Certified Porsche addict
Go ahead and take the door panel off. It's not that difficult. I had problems like yours but with the additional factor of a broken multi-connector on the passenger switch. I couldn't tell if it was pinned correctly. After I pulled the door panel I found several other issues. One of the previous owners had installed an early 944 window motor, the wires had been extended to reach the incorrectly positioned connector on that motor. That extension had someway been cut (probably by the lift mechanism) and the exposed ends of the wire were shorting out on the door frame. To replace the motor you will have to pull the lift mechanism out of the door. Really not that hard. Just clamp the window in raised position with padded wood clamp and take the screws out that secure the lift mechanism to the door and the window track. Fold it up and slid it out of the door. To be completely sure I not only replaced the motor but also the passenger switch and spliced a good multi-connector on the harness. Everything works great and I'm glad I took care of everything at once.
Tennessee Region SCCA & PCA Current projects - '87 944 Turbo, '87 924S, '82 931, '10 Boxster (the girlfriend) Past projects - '83 944, '02 Boxster (x2), '99 Boxster, '14 Cayman,'72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '07 Cayman S, '73 914, '88 MR2 AW11 |
