Greasy Member
many944s's Avatar
Has anyone seen an intake port like this before?
In the process of rebuilding these heads, I came across one that was different then the others?!? In fact, I have NEVER come across a 944 head quite like it!
Just inside the intake port, there is a notch. They are not machined, they are cast into the head, as they have the regular rough cast finish. They appear to be lands where the injector would fire, but as I said of the 40 or so heads I have seen over the years, this is the only one I have seen like this. It has the standard part number (944.104.303.6R). Here are some pics, first of the oddball, then a typical head with the same part number:
Any ideas?
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 08-25-2008, 05:28 PM
meister member
speedracing944's Avatar
That is how my '83 head is. It has the notch as shown in your top picture. The head off the '85.5 does not have the notch.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 08-25-2008, 06:23 PM
fast924S's Avatar
Send a message via AIM to fast924S
That is very odd. Never seen that before, My 87 does not have that, Maybe on the early heads they did that to help in fuel atomization by making more air turbulence in the area of the injector spray
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 08-25-2008, 06:32 PM
My 944 scares adults
lovemy924S's Avatar
Send a message via AIM to lovemy924S
is this my head? just asking because if it is it's out of an 84
1987 Porsche 944 (black) with a 1997 LT1 5.7L V8, BBK 58mm TB, fully ported intake, LT4 Hotcam, Comp Cams 1.6 Rockers, LS1 MAF, Custom Dual 3 inch exhaust through 2 Flowmaster 50 series mufflers
1986 Porsche 944 Turbo, 1989 944 Turbo S engine with K26-8, MBC, knockoff Turbo Twist wheels, test pipe, Ansa cat-back, Chipped (Auto-Authority?)
Old 08-26-2008, 03:17 PM
I dont remember my 83 head looking like that
Old 08-27-2008, 05:58 AM
