Fuel Injector Seal Kit (924S)
I have a 1987 924S, and currently working on the fuel injectors. I bought some seal kits, but they do not seem to fit the injectors I have. Every web site I found seemed to have the same seal kits, but they don't seem to fit. First, the plastic "washer" is too large both in width and diameter compared to the original. Second, the cap that snaps over the injector tip is too high compared to the original. The black rubber seals seem to fit okay. The part set I got is 1.287.010.704 and supposedly replaces 94411090100. Not really sure what to do. Trying to avoid springing for new injectors, but I can't find the seal kit that looks like it will fit on the web. Any suggestions?
Old 08-26-2008, 06:35 PM
fast924S's Avatar
Send a message via AIM to fast924S
I had the same problem when I did mine, I think its the wrong parts, The yellow cap covers to much of the injector opening, Thing is when I was doing mine, I slipped and Broke the injector pintel off, SO I just went and got 4 brand new injectors LOL
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 08-26-2008, 07:21 PM
working in the garage
JHinOH's Avatar
I recently sent my 924S injectors off to Marren for cleaning/blueprinting and they return them with all new caps and o-rings. They corrected a difference of around 5% variance between injectors and improved flow 4cc's each for around $100, I know you can get it done even cheaper if you look around. I would go this route before you start buying new injectors. I bet if you called them or another comparable injector shop they could get you the right parts also. Just something to consider.
Old 08-26-2008, 08:23 PM
Proprietoristicly Refined
John_AZ's Avatar
I found the set that matches original at a VW parts house. Matched part for part. $4. per injector. You do not need new injectors. Our tech section-look at top of page-has a cleanout DIY from a pro wrench. If you get really stuck send them to www.Witchhunter.com for clean and balance. Returned with new O rings and hats. Look for a VW parts house locally.
Good Luck
John_AZ
1988 924S + 1987 924S both with VW kits, DIY clean, and purring
Old 08-26-2008, 09:46 PM
Rennbay has a kit with the correct spacers and hats...
Warren
'87 944S
"Tubes sound better"
Old 08-27-2008, 08:53 AM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Do yourself a favor and send them off to witchhunter. not only will they replace the orings & hat, but they will clean and flow test them too, and send you a nice chart about before & after. Well worth the money.
if one of them is bad they will most likely have another one they will sell you for only $25 like they did for me.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 08-27-2008, 10:01 AM
fast924S's Avatar
The rennbay ones are NOT the correct ones, Those are the ones I used and they didnt fit right.
Old 08-27-2008, 03:24 PM
Redline Racer
HondaDustR's Avatar
+1 for witchhunter. They did a great job on mine, and were all within 1cc flow of each other.
See this thread for the gorey details.
Fuel injector job in pictures.
BTW, I have 4 working injectors if you turn out needing some.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 08-27-2008, 09:05 PM
the rennbay "blue" hat kit?
the "yellow" hat kits everywhere else were the ones that were too big for my injectors, but the rennbay blue hat kit was the same as the original hats and spacers. It took a lot of carefully applied pressure to get them to seat properly though
Warren
'87 944S
Old 08-28-2008, 07:50 AM
