North Coast Cab's Avatar
Throw Out Bearing Assembly
Anyone know the order of parts to install a new throw out bearing in a new PP?
I have the following:
1 - Cirlip
1 - Large grooved washer for circlip
2 - Thin washers
1 -Serated cove washer
TIA, John
1985.5 944 GTS
Old 08-30-2008, 06:24 PM
Proprietoristicly Refined
John_AZ's Avatar
With Pictures:
See post 18
http://forums.pelicanparts.com/porsche-911-technical-forum/290135-how-remove-throw-out-bearing-retaining-ring-post4118892.html
No pictures:
See Post 2
http://forums.rennlist.com/rennforums/showthread.php?t=448359&highlight=throw+out+bearing
Good Luck
John_AZ
1988 924S + 1987 924S
Old 08-30-2008, 07:19 PM
Nobody Special
Place the TOB face down to the ground with the tube body facing up. Shim washers next, then the toothed washer with the teeth facing down. Place the pressure plate over these and put your knees on the edges to compress everything. Next goes the thicker spacer washer and the circlip. IMO the key is getting as many shims on there as yo can and still be able to install the spacer washer and circlip. After all is assembled spin the circlip around the groove with an awl or screwdriver to make sure it's fully seated; having that circlip come loose down the road is a serious heartbreaker after all that work. I've used 3 shims twice now for a new Sachs kit.
Edit: Looks like John beat me to it
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 08-30-2008, 07:29 PM
John_AZ's Avatar
2Tight,
I used 3 shims as well, I thought it was still "loose" enough.
John_AZ
Old 08-30-2008, 10:12 PM
