Cant get gear oil 17mm nut out? Wishbone question.
Hey guys me again
OK tried to get the 17mm top nut out and there was no budgeing it. started to ring so i left it. its prity badly rusted as is the bottom one. So what do i do now? how do i get them out, and if i get them off is it possible to get new ones?
also both front wish bones are fairly well rusted so as a safelty precaution i will replace them.. is this a big job??
any help at all would be great.
1986 manual 5 speed 924s 2.5l
Kosh
Old 09-05-2008, 09:13 AM
Non Compos Mentis
New ones are available here at Pelican Parts. Just soak them in WD-40, PB Blaster, or some other penetrating oil and let them sit overnight. Adding a little bit of heat always helps break things loose.
Old 09-05-2008, 09:17 AM
soaked them for 2 days mate...still didnt help..but thanks for the advice.
Kosh
Old 09-05-2008, 09:23 AM
That Guy
Techno Duck's Avatar
Heat them up with a torch, then try removing them again.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 09-05-2008, 09:33 AM
Quality
phoenix_iii's Avatar
What happens if they are totally destroyed (rounded out)?
What would be recommended then? (almost ran into this myself)
85.5 944 NA 5spd - Sold but not forgotten
89 951 Turbo S - Revival in progress...
Old 09-05-2008, 09:39 AM
Back from Beyond
Drill, heat, easy-out.
I'm putting this off, too. Actually, I dodged it when changing my transaxle seals by jacking up one side of the car high and filling the tranny through the flange hole while the flange was out. In my world, 6 CV bolts were easier than 1 fill plug!
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 09-05-2008, 10:37 AM
Sears craftsman sells something called a Bolt-out. It removes stripped or rusted nuts/bolts. I have a set and it has been one of my best tools, everyone that has seen it, has gone out and got their own set with great results.PN 009-52062 My outdated cat. says $49 . Good luck. Brian
Old 09-05-2008, 11:45 AM
70SWT's Avatar
To reinforce what others have said: for intact bolts that are just stuck here's what I do...PB Blaster overnight for several nights in a row...then heat with a torch...then, if not a perfectly snug fit due to slight rounding or variances, cover your hex head with aluminum foil to fill any void...make sure its perfectly straight in and fully seated, dig any gunk out of the plug recess first if needed, and use a good breaker bar for well-controlled torque...repeat the process if no go...
2018 911 Carrera coupe
1972 911T targa
Old 09-05-2008, 12:01 PM
I had a fill plug that was so badly rounded out that I had to weld a bolt with a 17 mm head into the plug, then use two pairs of vise grips on the shank of the bolt to remove the whole mess.
Please, please, please, tell your mechanic that it doesn't have to be that tight... just tight enough so that they don't vibrate out.
Good luck, George Beuselinck
Old 09-05-2008, 12:25 PM
Toofah King Bad
Rasta Monsta's Avatar
ŧ 1987 924S Turbo - Got Boost? Ŧ
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 09-05-2008, 03:30 PM
Mountain Road Maniac
ColoradoSteve's Avatar
I feel your pain...My fill plug is completely rounded out and there's no way the 17mm is going to get it . At least the drain plug loosens easily. I have a new plug to put in, now it looks like I'm going to have to drill and use a bolt extractor. Is there going to be a problem with bits of metal going into the tranny?
'83 944
'87 951- SOLD!
Old 09-05-2008, 06:36 PM
Its never a good thing to have bits of metal floating around in your transmission.
Old 09-05-2008, 06:52 PM
Just thinking out loud
mattdavis11's Avatar
I had to use an impact gun on mine the first time I changed the fluid. The only way it would come out was air gun to 17mm hex, no extensions. I could only get the car so high in the air, and the breaker bar wasn't working.
91 FJ80
84 Ram Charger (now gone)
Old 09-05-2008, 07:01 PM
I had a 924 4 speed transmission with a rounded out fill plug. I welded in an old 1/2 drive socket and out it came. I think the heat from the welding helped break it loose.
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 09-06-2008, 05:18 AM
Send a message via AIM to Lapponia
Hi! Why canīt we use the same thin Teflon tape as plumbers use in pipe connections? This tape must be able to withstand all temperature swings that can appear in our transaxles as well as in pipeing. I will try this in the next oil change.
____________________________________
Lapponia 944 na 1984
Old 09-06-2008, 07:40 AM
I do, works great.
91 FJ80
Old 09-06-2008, 12:39 PM
Teflon tape, teflon pipe thread sealer, or antisieze on putting new ones in.
drew1
wife has 924 turbo
Old 09-06-2008, 01:31 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
wishbone replacement
The front wishbones are easy to replace, and the steel ones are cheap. Buy all new bushes and bottom ball joint whilst you are at it. Mark around the rear wishbone mount prior to removal to get a base setting for alignment when fitting on the new wishbone.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 09-08-2008, 02:39 AM
Mission F#%@@*g Accomplished!
Geez, that was fun, that plug was really stuck. After I got the easy out started, I heated it up, then it took a wrench with a 2' breaker bar .
'83 944
'87 951- SOLD!
Old 09-09-2008, 04:40 PM
