1984 porsche 944 na
Lock cylinder pinning kit?
Anyone know where I can find one so I can use same key to open door ignition and hatch? Or someones got left overs I can buy? Just have to do the hatch lock.
Trying to work for parts!
Believe the hatch lock is pressed in and sealed. Not sure you can do it. Might be better off changing the doors to match the hatch.
Otherwise check with local locksmiths. Should charge you around $20 per door to do it.
86 Metallic Grey 85.5 Metallic graphite - Gone |
1984 porsche 944 na
Good info I will check into that..I dont have a key for the hatch so I would have to start there..Thanks
