Replacement mirror glass?
I was driving home from work today and the glass just fell out of my driver's side mirror and shattered everywhere!
A replacement glass from pelican/944online is pretty expensive...will this work instead: |
yeah should work. Also check in the parts section on here, so many cars being parted (sadly) but not many people are looking for the mirror glass. GL
Steve- If you havent looked, look- www.clarks-garage.com 87 951 red- Maria (current) 84 944 white- Percilla (current DD) 85.5 944 red- Pinta (past) 87 924S red- Nina (past) |
If you still have the support mechanism that the mirror glass is glued onto shure it will work.
Catalin '86 DD |
Great! Thanks guys
Nobody Special
Make sure it's not actually a piece of Mylar or mirrored acrylic that goes over cracked glass. That's about 75% lower than any glass source I have seen.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD 91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD 86 - 951-K26/8, daily driver-SOLD 87 - 944S - Another daily driver-SOLD |
From under the mirror, simply turn the plastic locking ring, the mirror can then be removed from the casing. take that to ANY glass/screen shop nearby. They will fit in a new glass mirror, just like new, for about 25-30 bucks.
plastic mirrors are a PITA. they dont last long, and the one that PO put on my car nearly cased me to crash it on the way home.
1995 993 C2 |
Just had one cut a a glass shop and siliconed it on. Take pattern off mount to shop and they can make one .
The wing mirrors have an electric element as they are self heated and self demist
bear this in mind !!!!
----------------------------------------------------------- The fear of God is the begining of wisdom <>< NotJustPorsche Subscribe: notjustporsche-subscribe@yahoogroups.com |
Think it will melt the silicon?
remove the mirror mounting plate, take that whole piece to the glass shop, they will fit, and glue the mirror onto that piece themselves. it will be a professional job that will not come apart.
1995 993 C2 |
i replaced mine with a brand new original one and it was really cheap - something like 30 bucks
Non Compos Mentis
I just had my passenger mirror replaced at the local glass shop for $30.
is there a difference from the early to late model driver side mirror glass?
mine flew off yesterday going about 80 and i need to get a replacement for obv. safety reasons
1984 944 NA A wise man once said, "Speed cannot be complimented with control, and that control is achievable only without speed." That man obviously has never driven a Porsche |
