1984 porsche 944 na
ballysdad's Avatar
Headlight electrical
I have read clarks garage write up and will follow procedure tomorrow. Checking here first My headlight will go on and pop up but will not retract. My taillights and my dash lights are out fuses are ok. I have spent half the night reading post with the same problems with no real resolution at the end. I did see 2 posts that mentioned the Blue wire at the fuse panel was shorted. Has anyone else found this to be the case?
cliffnotes: headlights work.. go up.. won't go down
dashlights and rear taillights are out as well
Fuses are ok
Old 09-10-2008, 08:05 PM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
guessing here
Switch? The switch is common to the sytems affected. Remove it by reaching waayyy up into the dashboard and squeezing the tabs. Then check for power going to the hmmm..on my car it is the red/green wire that controls the down circuit. Also check for power going to the rear lights. The dash dimmer is integral to that switch as well. Check continuity after you clean all the connections on the back of the switch and in the socket.
Good luck.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 09-10-2008, 11:25 PM
1984 porsche 944 na
ballysdad's Avatar
Thanks.. Anyway to remove the switch without access to back of switch? I am working on a 1984 944 NA.. Thanks ..don't want to force cover on switch if it can't be released from the front.
Old 09-11-2008, 06:31 AM
Cars & Coffee Killer
legion's Avatar
Do you have a multimeter? It makes diagnosing electrical problem MUCH easier.
5 liters of VVT fury now
-Chris
Old 09-11-2008, 06:46 AM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Since we aren't mind readers and you dont have the information posted, what year car?
I think you had asked this on another forum too and it was suggested to replace the switch.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 09-11-2008, 02:04 PM
1984 porsche 944 na
ballysdad's Avatar
It is a 1984 944/1 If someone could tell me how to edit my car and location I would love to do so. I cannot find my profile settings anywhere.. Oh yeah can I pull the switch out by prying from the front or does it have to be released from the back?
Old 09-11-2008, 04:04 PM
Look up at the top of the page and click on where it says user cp
86 Metallic Grey
Old 09-11-2008, 05:26 PM
1984 porsche 944 na
ballysdad's Avatar
Found it thanks... unplugged at headlight motor put test light with switch off power to position 5 turned healights on power on position 1 and 5 but blew fuse 1 for motor somehow. Now I have dashlights and tail lights... but no up or down.. gonna replace fuse and see what happens.. One of the wires was a little loose in the harness so I will see when I get another fuse in there too dark out and fashlight died
Old 09-11-2008, 05:41 PM
Back from Beyond
Check your ground connections at the switch - they tend to work loose and if you lose good ground your headlights won't come down. Be careful tinkering with this part of your wiring, because many early 944 electrical fires are the result of this problem. When you've got it teched out, install more grounds and the problem will vanish. Ground wires are all brown. Also, pop out the blues connector behind the fuse panel. I'll bet you'll find burned spots on it. It's easy enough to replace with some time and a soldering gun. The switch itself can be rebuilt, as the contacts inside benefit from a light sanding. When you take it apart try not to lose the balls and springs.
Good advice - don't lose your balls!
Good luck!
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 09-12-2008, 09:52 AM
strikinglight's Avatar
Just had this happen as well. Slam is right on this. The blue connector is part number OEM-171971971B If you need a new one. I did as it burned right though it!
Also consider upgrading the headlight wiring to something like this http://www.rennbay.com/porsche-944-headlight-relay-harness-p-111.html?osCsid=a245af4fdf2f0253ee7de84f166c9f2d
MUCH Cheaper then fixing the aftermath of a fire... Trust me on that one.
Jordan
86 944 n/a Bought to drive...now project
84 944 n/a Bought to feed project... Now I want to fix it!
Old 09-12-2008, 10:45 AM
