1984 944 No start in the cool mornings
Now that the weather is changing I'm having problems starting my 944 in the mornings without a dose of starting fluid.
It's been in the 90's during the day and 50's at night here.
I'd say it's a fuel problem, but if sleep in (noonish, or like this weekend where I had it on jack stands all weekend) it'll fire right up fine on the first crank without the spray bottle. So I don't believe its a check valve or a damper or regulator or leaky injector draining the system.
I don't think its a spark issue since it fires up either way.
For these reasons I'm pretty sure its temperature related.
Any clues where to look??
Life's short
Go fast
Have a blast
Leave a good looking corpse in a 84 944
Old 09-15-2008, 09:20 PM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
Get a multimeter and test the voltage in your battery after you've left the car overnight. If its 12.5 or less, you may have a short thats draining the battery at night or you may have need of a new battery.
I had the same problem last year and discovered a short in my dome light that would drain the battery at night. In the colder morning I could not get the car to start but if I waited till later in the day, the car would start.
I am not familiar with the physics involved but I know this worked for me.
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 09-15-2008, 09:57 PM
Sorry, forgot to mention that I don't have a problem cranking my life away.
I just put a new battery on it back in June when I got serieous about getting this beast running. It had been sitting in a barn for 4 years after the PO broke a timing belt.
I'll get the multimeter out of my tool box when I go home this weekend.
Life's short
Go fast
Have a blast
Old 09-16-2008, 07:01 AM
